Stage 3 cossie only boosting about 10psi?
Old Jul 15, 2004 | 10:08 AM
rog's Avatar
rog
Default Stage 3 cossie only boosting about 10psi?
Apologies for posting this in the general discussion but i did post in the Technical one but didn't get many responses.
Here's the problem, my car only seems to want to boost to around 10-12psi, i have changed the actuator, amal valve, hoses, and intercooler since this happened but i still can't figure it out, any suggestion welcome. Other that that the car is running as good as gold, no misfiring, it basically drives like a standard car, which is not what i want.
Thanks in advance, Rog.
Old Jul 15, 2004 | 11:23 AM
rog's Avatar
rog
Old Jul 15, 2004 | 11:30 AM
JRST's Avatar
JRST
air leak. mate check all your gaskets.
Old Jul 15, 2004 | 11:35 AM
rog's Avatar
rog
Done that too, away to get ANOTHER actuator and try that again. Cheers anyways.
Old Jul 15, 2004 | 11:41 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
boost hose colapsing maybe?
Old Jul 15, 2004 | 11:50 AM
Sticky.'s Avatar
Sticky.
Faulty boost gauge maybe
Old Jul 15, 2004 | 12:40 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Maybe the wastegate doesn't close fully???
Old Jul 15, 2004 | 02:37 PM
sf's Avatar
sf
take off the amal valve and replace it with a bleed valve?
Old Jul 15, 2004 | 02:41 PM
Nick500's Avatar
Nick500
Why do that? that is what the king of Rough Bastids would do!!! Rog as I said check that your Actuator is set right, there was no sign of air leaks and no probs other than lack of boost!! By the way will have your bumper from Bob
Nick
Old Jul 15, 2004 | 04:32 PM
rog's Avatar
rog
Ok cheers dude, so r u having the whole car then, another one to add to the collection??? Definately not going near any bleed valves i hate them with a passion! I've ordered a garrett -31 actuator, should get it tomorrow but i don't think that's the problem. i've had the turbo off and checked the wstegate, there's nothing odd looking there either. Cheers for your input guys
Old Jul 15, 2004 | 04:39 PM
RSCAT's Avatar
RSCAT
RSCAT tip number 1.
check the fuse in by the ecu before anything else
Old Jul 15, 2004 | 04:41 PM
RSCAT's Avatar
RSCAT
or just pull the amal valve off and see if it pops, if not itll be that fuse im on about.
Old Jul 15, 2004 | 07:45 PM
wimwerf's Avatar
wimwerf
what about your dump valve. do you have one with a piston or not. maybe your dv is leaking air under pressure.
Old Jul 15, 2004 | 07:55 PM
Alvyn's Avatar
Alvyn
disconnect the actuator rod from turbo and make sure that penny is closed properly before you refit and adjust to your required boost settings
Old Jul 16, 2004 | 01:41 PM
rog's Avatar
rog
Cheers, i've tried all that, removed the dump valve etc..... got a new actuator, checked the amal valve, changed the hoses and intercooler, but still no more boost, i just cannot find ANYTHING wrong! yet the car runs as tho it's standard, pulls well for the boost it's running.
Old Jul 16, 2004 | 01:45 PM
sf's Avatar
sf
stuff then
Old Jul 16, 2004 | 03:04 PM
rog's Avatar
rog
Just wandered if it could infact be the MAP sensor, but the car seems to run ok otherwise.
Old Jul 16, 2004 | 03:23 PM
stevo's Avatar
stevo
turn ur actuator clockwise a few times
Old Jul 16, 2004 | 03:38 PM
rog's Avatar
rog
Beliveve it or not i've actually tried that.......
It's the 3rd on i've tried so it can't be that, it was boosting about 20 odd psi for about 2 years and then one day it decides to go to about 10 without me touching anything.
Old Jul 16, 2004 | 03:47 PM
sf's Avatar
sf
your ecu might be shagged
Old Jul 16, 2004 | 03:48 PM
rog's Avatar
rog
aye........
i'm gonna have a look at that later on, fucking HATE electrical problems!
Old Jul 16, 2004 | 06:46 PM
Kev H's Avatar
Kev H
Have you got your old 2 bar MAP sensor? if so swap it and see if the boost goes up a bit!
Old Jul 16, 2004 | 06:51 PM
cossie1's Avatar
cossie1
try connecting the hose direct from the turbo to the actuator
and see if the boost changes atall
if it drops lower then adjust the actuator up and see if the boost will now go above 12 psi
Old Jul 16, 2004 | 07:08 PM
Jim Galbally's Avatar
Jim Galbally
you could take the hose off the actuator (so the wastegate wont open) n see what it boosts to... if it shoots off the boost gauge n goes like stonk then the wastegate/turbo's probably ok n its just setup wrong... if it still boosts to about 10-15psi then you have a problem with your turbo and/or wastegate
Old Jul 16, 2004 | 08:33 PM
kennert's Avatar
kennert
do like i did yesterday;
Take off hose at actuator, then it will run full (as actuator is adjusted). when full boost is adjusted put hose back on actuator for ECU controll of boost.
Cheers Kennert
Old Jul 16, 2004 | 08:44 PM
Spiky's Avatar
Spiky
run engine
and unplug amal valve it it clicks when u connect it it working.
acutator weak????? is it a -31????
Old Jul 16, 2004 | 10:00 PM
dave cos4x4's Avatar
dave cos4x4
Spiky,
run engine
Mine was clicking and it was only giving me 15 psi,then it would give me 25?
changed the amal valve over,all o.k. now.
Dave.
Old Jul 16, 2004 | 10:05 PM
Spiky's Avatar
Spiky
leaking amal then
they do tend to split
Old Jul 19, 2004 | 12:30 PM
rog's Avatar
rog
I've got a new amal valve and -31 and i pressure tested them both with a pump, think it may be the turbo just struggling now. I cranked up the boost today and it only hits 19psi peak, i was giving it some on the way to work 2day and it cut out when i was in 4th about 5k rpm, pulled into the side and it statred again first time so it seems like something electrical could be causing it? Give me strength!
Indyrs
Dec 4, 2022 12:39 PM
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
Marino
Sep 12, 2015 11:10 AM
