saph 4x4 question
when changing the clutch i know the box has to come out but does the transfer box come out aswell ?
how easy is it change the oil in the transfer box and the front and rear diffs ?
any help much appreciated........matt
also piss to change the oil in all three diffs
are they the same ones as the workshop 1 and 2 manuals gareth ?
if so they are in my boot lol
what oil should be used in the diffs i know the transfer box has auto gearbox oil in it and the gbox has special oil in it
how much oild does the transfer box and the 2 diffs need ?
got the mt75 oil sorted from gearboxman
sae-90 oil............. is that just the same as automatic gearbox oil ?
the transfer box only needs half a litre of oil in it
the 2 diffs need i litre
just been told SAE-90 oil is gear oil so i need 1 litre of automatic oil for the transfer box and 2 x 1 litre of SAE-90 hypoid gear oil for the diffs
is this right with other people ?
to change the oil in the diffs, is it a case of taking a drain plug out or do you have to take the casing apart etc
if so do you need any new gaskets or anything to do this ?
dojj
28
Sep 11, 2015 10:00 PM
truffleshuffle
Sep 10, 2015 09:35 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
