2wd Saph Cossie Underbody Restoration(pics added 15th march)
Old Dec 26, 2005 | 10:36 PM
twitchyrear's Avatar
twitchyrear
Default 2wd Saph Cossie Underbody Restoration(pics added 15th march)
My car has been sorn due to the moody weather since the end of october,i was just going to do a service and aeroquip the oil breather system, more for asthetics than anything else.I then decided after seeing a few good jobs on here that i would have a go at tidying the underside of my saph up ready for the spring/summer.i want the car set-up and on the road by mid-april so ive got plenty of time to do it.Right,here goes the list of things i want to do:
strip the underside of all componants
strip all remaining underseal
repair any holes or billy
rust treatment & hammerite/waxoyl underseal
new bilstein/gaz coilovers
new back brakes
rear end fully polybushed
powdercoated rear beam
lots of underside colour coding
aeroquip oil breather system
big front calipers&discs
This is the garage ill be working in(tight!)
heres some pics from underneath,
diff&shafts will be shot blasted and powsercoated
ill replace all lines with new
not looking to bad,so far
fuel tank removed,not looking bad again
might be worse when stripped back
fuel pump cradle removed
looking a bit tired
nice!!!!!!!!!!!!!!!!!!!!
coilovers seen better days
random shot
another
got a new fuel tank,primed it,just got to decide on my colour coding now
ill be taking the rear beam complete with diff ect off this week and be doing a bit of other work so will post pics up probobly every day,once everything is off underneath ill be able to get a good look at the rails and see what sort of job ive got ahead.ill keep you posted.cheers for your support
Old Dec 26, 2005 | 10:40 PM
twitchyrear
any chace of someone sorting out the size
Old Dec 26, 2005 | 10:55 PM
nolag's Avatar
nolag
good to see another one getting the treatment mate,good luck with it and keep the pics coming
Old Dec 26, 2005 | 10:58 PM
lamb chops's Avatar
lamb chops
Great to see this, I did my old Saff last year over the winter. If you want any tips drop me a PM. You cant get the metal fuel lines anymore though mate, I wirebrushed mine down and painted in hamerite, looked fine when complete
Old Dec 26, 2005 | 11:08 PM
twitchyrear
cheers for that info mate,is there anything else i should know??
Old Dec 27, 2005 | 06:42 AM
Good luck with the resto ,and keep the updates coming
Old Dec 27, 2005 | 09:11 AM
Moondust_crust's Avatar
Moondust_crust
ahhh thought you was just gonna dry store it over winter mate, good to see ya doin soo well!
keep up the good workŹ!
cheers mark.
Old Dec 27, 2005 | 12:13 PM
Tom Baxter's Avatar
Tom Baxter
Good luck mate, keep up the updates.
Old Dec 27, 2005 | 12:16 PM
twitchyrear
LAMB CHOPS
TWINS
MOONDUST CRUST
TOM BAXTER
Cheers for your comments,and thanks for looking
Old Dec 27, 2005 | 12:18 PM
nolag's Avatar
nolag
nice to see youve resized the pics twitchy,makes it better to see whats going on
Old Dec 27, 2005 | 12:35 PM
twitchyrear
just an update,only the pumps and cradle but here goes
nasty and crudy
semi stripped,managed to salvage the rubbers so will strip it,treat it and paint it back up
stripped,treated and primed
did all the stripping and priming on xmas day and boxing day.
later ill be taking off my rocker cover,separator,mirror breather off and taking em to radtec to have some threaded lugs welded in ready for the aeroquip,ill post some pics of the bits when i get them off
Old Dec 27, 2005 | 12:38 PM
nolag's Avatar
nolag
bloody hell,im strugglin to keep up,.keep the pics coming
Old Dec 27, 2005 | 12:53 PM
lamb chops's Avatar
lamb chops
Wow looking good!! I would recommend powder coating if you can as it last so much longer than paint. I had my fuel cradle, rear beam and arms all bead blasted and then powder coated black, didn’t cost too much and was a real nice finish that should last forever..
I have a thread on here somewhere when I did mine.. will have to fish it out for ya.
Old Dec 27, 2005 | 03:41 PM
Moondust_crust
oooh we like,
has the garage got electric mate ?
Old Dec 27, 2005 | 08:46 PM
twitchyrear
no mate,but sister lives over the back so i just unravel a 50m extension lead for my elec ,its a council garage so i have to shut my self in so no scally can catch a glimps of it and come back at a later date to rob it or from it
Old Dec 27, 2005 | 08:48 PM
twitchyrear
everything else will be powdercoated matey,as i agree you get a quality finish and will way outlast paint,cheers for your input matey,i will have a look at your resto in a bit
Old Dec 27, 2005 | 08:51 PM
nolag's Avatar
nolag
Old Dec 27, 2005 | 09:29 PM
whitecossie's Avatar
whitecossie
looking good mate , mine looks nice from the outside but underneath needs some tidying once we get a bit half decent weather ill be starting mine ,
Old Dec 27, 2005 | 09:49 PM
twitchyrear
went down today and took all my bits off ready for radtec to weld some threaded lugs into my cam cover,3 on the oil seperator and 1 on my mirror image breather(quoted me Ł80)
cam cover and breather bits off
another view
looking flakey(phone pic)
so i stripped it back(phone pic)
Will be going down to take the back end off tomorrow,ill be on my own so hopefully ill get it done and post a few more pics up 2mrw night
Old Dec 27, 2005 | 10:17 PM
CosKev3's Avatar
CosKev3
Nice 1
Big job though
Did under rear arches/tank/boot floor on mine last winter
Done under front wings so far this winter,powdercoated front crossmember and susp,fitted re-con rack,new eng mounts and adj TCA's so far
Hoping to do all the rear beam,but not sure if will get time.
Couple of pics of back end:
Old Dec 27, 2005 | 10:23 PM
twitchyrear
Originally Posted by CosKev3
Nice 1
Big job though
ive seen some of your work kev,you seem to know what your doing,you also seem very proud of your car after seeing what youve been spending .if we do get the covoy going in the summer mate at least we know we'll be doin it in a couple of minters
Old Dec 27, 2005 | 10:28 PM
BlackSaff's Avatar
BlackSaff
Nice one mate, another one being treated. I think you've read mine so you'll know i'm a little bit further down the road, any probs just PM me I might be able to help!
I've scrapped my metal fuel lines as they were FOOOOOOOOKED but i'm gonna replace them with Aeroquip ones, if yours are fooked it's a path you could look down. Like chops says Powder coating will last longer and looks loads better!
Keep up the good work
Old Dec 27, 2005 | 10:29 PM
nolag's Avatar
nolag
will you be able to get the rear end off on your own twitch?? good luck anyway but wrap up warm as its ment to be colder tomorow
Old Dec 28, 2005 | 09:15 AM
BILLY's Avatar
BILLY
Coming on nicely that is Really want to do this to mine but I haven't got a garage and I don't fancy laying in the snow. Might do it in the summer. Anyway, keep up the good work and keep the pics coming
Old Dec 28, 2005 | 09:16 AM
CosKev3's Avatar
CosKev3
Nice 1
Big job though
Thanks
Will be 3 minters atleast,my m8 Humper will be up for it too
3 white minters
Old Dec 28, 2005 | 09:20 AM
CosKev3's Avatar
CosKev3
Been a bit of debate on here regarding MOT's and aeroquip fuel pipes under the car,pretty sure its a MOT fail.
Do a search
Old Dec 28, 2005 | 04:47 PM
BlackSaff's Avatar
BlackSaff
I will! I'll check my handbook, I'm an MOT inspector so i'm not overly worried!!!
Since had a look in the online Handbook, don't see what the problem is. Fill me in CosKev whats been the issue?
Method of Inspection
Running the engine
This inspection is to be carried out both with and without the engine running.
1. Check the following for leaks or insecurity:
a. fuel tank Reason for rejection a. fuel leaking
b. all visible fuel hoses, pipes and unions Reason for rejection b. a fuel system component insecure.
c. all visible fuel components
Opening the luggage compartment
It may be necessary to open the luggage compartment to carry out a full inspection of the fuel system.
2. Check fuel tank cap for positive fit and condition of sealing washer and flange.
a. fuel cap does not fasten sercurely- by a positive means, or- such that pressure is not maintained on the sealing arangement
b. fuel cap sealing washer torn, deteriorated or missing, or a mounting flange/sealing method defective such that the leakage of fuel is possible
Locking fuel caps
If access cannot be gained to the fuel cap because it is locked and the key is not readily available or because it cannot be opened for some other reason see heading 2 of the introduction of this manual.
Old Dec 28, 2005 | 05:11 PM
bailey1's Avatar
bailey1
hi mate its dave this was my car you had of me looking good mate keep the updates coming with plenty of pics i look forward to seing it at the shows next year if i get my my 3 door finished in time.
Old Dec 28, 2005 | 05:32 PM
Moondust_crust
come on come on update, did ya get the rear beam of twitchy?
cheers mark
Old Dec 28, 2005 | 06:24 PM
CosKev3's Avatar
CosKev3
Can't see any1 arguein with that m8,just a post I read in gen discussion couple weeks back
Old Dec 28, 2005 | 08:42 PM
twitchyrear
right just a quick update,i went down to start to take off the rear but it will take longer than i thaught,basically every nut and bolt are corroded beyond belief it took me an hour just to undo the flexy brake pipes from the body then i relised whilst on my back that the exhaust has got to come off so that took me an hour by this time i was getting a bit frustrated as i only had a bedside table light to see and limited space to work in but the prep work has been done i suppose,ill go down and get it off tomorrow,but i think ill call at b&q for some propa strip lights first.sorry theres no pics but ill get some up tomorrow.I will just add that this is a massive job for me as all my machanicle experiance basically just involves changing alternators,starters and brakes thats about the most exiting ive ever got with a spanner set so please dont expect me to be grease lightning,cheers to everyone for your replies
Old Dec 28, 2005 | 08:46 PM
BILLY's Avatar
BILLY
Keep at it mate, hope it gets better for you, I'm sure It will look mint when you've done it
Old Dec 28, 2005 | 09:09 PM
nolag's Avatar
nolag
keep plugging away twitch,just look at it as nuts and bolts.if you get stuck you know theres always somebody who will have an answer for ya
Old Dec 28, 2005 | 09:11 PM
Moondust_crust
mate just wanna say you have done sooo well over the last few days considering that you havent done much on cars before, its the same with my cabby when i was stripping it, you think something will take you an hour, it takes you three! lol, keep up the good work, it will get there in the end
cheers mark.
Old Dec 31, 2005 | 04:21 AM
thebigyin's Avatar
thebigyin
just started doing the same to mine, looking good m8
Old Dec 31, 2005 | 02:06 PM
lamb chops's Avatar
lamb chops
Can you MOT your own cars then? very handy of so
Looks like you may be getting a load of cossys to MOT with braided external fuel lines next year
Old Jan 1, 2006 | 12:20 PM
mike77cos's Avatar
mike77cos
This is the inspiration i need
Old Jan 1, 2006 | 12:34 PM
nolag's Avatar
nolag
update????
Old Jan 1, 2006 | 01:15 PM
twitchyrear
will post a small update with pics tonight
Old Jan 1, 2006 | 05:56 PM
lmans123's Avatar
lmans123
good work there
