rust ? waxoil?
Old Dec 26, 2005 | 11:28 AM
JayRS2000's Avatar
JayRS2000
Default rust ? waxoil?
right dont mean to sound dum or anything want advice on how to do it properly ? ive jet washed the bottom off my car to see how things looked got 2 big ish holes size of a 50pence picece and they will get welded and did the same to the arches have a lagre amont of rust everywhere whats the best way to stop it getting worse ? clean then paste evenly with waxoil or rust stuff?????
cheers jamie
Old Dec 26, 2005 | 07:19 PM
ballin's Avatar
ballin
fighting a losing battle mate
all you can do is get it welded and treat the bottom with hammerite + waxoyl and hope that slows it down
Old Dec 26, 2005 | 09:32 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
rub all the surface rust off, sand paper/wet n dry/grinder (bit harsh), treat it with some rust treating stuff cover in stone chip, and paint i'd reckon. sure someone will correct me if im wrong
Old Dec 27, 2005 | 12:06 AM
antony215's Avatar
antony215
Escort Rs Turbo
Only way to do it is to cut all the rust out and have new plate's welded in
Old Dec 27, 2005 | 12:47 AM
SafeChav's Avatar
SafeChav
JayRS2000
And on top of that paint it VERY well, then lots of underseal on the underneath, cut it out properly and prep the new plates and they will last years. The only way to totally remove rust is to remove the whole panel, not very easy with the floor though
Old Dec 27, 2005 | 07:02 PM
Lighty's Avatar
Lighty
don't do anything till you have had it welded. Just makes it harder to weld
Old Dec 27, 2005 | 07:03 PM
SafeChav's Avatar
SafeChav
The painting bit i meant for after the welding has been done
badly worded
Old Dec 27, 2005 | 10:16 PM
rst in breaking's Avatar
rst in breaking
if your welding the floor take the carpet up and treat inside to other wise you'll create a rust trap due to it being untreated
Old Dec 27, 2005 | 10:36 PM
antony215's Avatar
antony215
Escort Rs Turbo
if he weld's the floor without taking the carpet up he will create more than a rust trap
id say he will create a BIG!!!! fire
Old Dec 27, 2005 | 11:45 PM
SafeChav's Avatar
SafeChav
Old Dec 28, 2005 | 05:01 PM
rst in breaking
its pretty obvious he has to take thecarpet upsome things dont neede saying but some people dont treat the bare metal thats unseen after welding
Old Dec 30, 2005 | 07:53 AM
scort19's Avatar
scort19
yeah cut more out than rust on my floor we cut about an inch more off around all the rust then plenty of stone chip then paint then waxoil .
Nov 1, 2015 06:53 PM
