Can someone explain---> Shot peening
Old Dec 25, 2005 | 06:08 PM
Mechanic_Wedgie's Avatar
Mechanic_Wedgie
Default Can someone explain---> Shot peening
What is it??
I've heard that it makes material stronger, true???
Old Dec 25, 2005 | 06:10 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
IIRC it's a process where metal ball bearings are fired at the metal at a high rate to close up all the gaps (pores) in the metal which then strengthens it.
someone may explain a bit more in detail
Old Dec 25, 2005 | 06:43 PM
NUTS RuS's Avatar
NUTS RuS
In a nut shell thats it
Old Dec 25, 2005 | 07:16 PM
The basic idea is to stop cracking on the surface of things like conrods which are under a lot of tension, its puts compressed "dents" into the surface that can the be stretched a little without tearing.
That doesnt read quite right, its one of those things i know what i mean but not sure how to explain it properly
Old Dec 25, 2005 | 07:26 PM
AlexF's Avatar
AlexF
It compacts the surface which makes it VERY hard.
This resists cracking - which is a good thing!
It also help to stree relieve the metal.
Alex
Old Dec 25, 2005 | 09:36 PM
The DIVA's Avatar
The DIVA
Its a form of stress relieving that basically gets rid of all the edges,working on the principle that cracks and fatigue fissures tend to propagate from edges,shot peening "rounds off" the edges and decreases the chances of a crack starting......
Much the same as if you drill a tiny hole in the outer surface of a cracked windscreen at the end of a crack,It will not go any further....
Old Dec 26, 2005 | 11:58 AM
Mechanic_Wedgie
Now i know what shot-peening is.
Cheers m8's
Old Dec 26, 2005 | 12:20 PM
Ginge !'s Avatar
Ginge !
just finding my feet
how long till theres a post mentioning there stone chip and they drilled through there screen when applying presure and then smashed the screen
Old Dec 26, 2005 | 12:34 PM
big_wig_074's Avatar
big_wig_074
thats stop drilling which is a touch different! dont go stop drilling your rods people!
Old Dec 26, 2005 | 01:49 PM
The DIVA's Avatar
The DIVA
I can imagine all the fooked rods post already....
Ignore that analogy then eh...
Rod-Tarry
237
Mar 18, 2016 09:13 PM
mark r
Sep 29, 2015 07:27 PM
gcfcos
88
Sep 15, 2015 03:48 PM
Mark Mawson
Aug 31, 2015 07:09 PM
