Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
single prop
Old Nov 30, 2003 | 10:35 PM
fatboyz's Avatar
fatboyz
Default single prop
hi people we have just striped the 1.1 engine and box out of a mk 2 scort to make space for a 2.1 pinto but i was wondering if i could use the prop it already has as it is a one piece type i was readind the latest classic ford where they do this conversion but the car they strip has a 2 piece prop any ideas
Old Nov 30, 2003 | 11:14 PM
biglez's Avatar
biglez
I've got a single piece prop for an RS 2000,nearly new,£50
Old Dec 1, 2003 | 08:25 AM
fatboyz's Avatar
fatboyz
where about are you les that price sounds great
Old Dec 1, 2003 | 10:25 AM
if u have a one peice prop in it allready then u can use that as it is the as an RS but if you are going to put on a capri atlas axle than u need the ends changed.
Old Dec 1, 2003 | 04:22 PM
fatboyz's Avatar
fatboyz
Default one piece prop
it might sound dumb but how do you change the ends ? is it easy ? what do i need to do ? and how much ? sorry for all the questions
does this sound ok 2.1 pinto capri 2.8i box my prop with capri ends ? and a 2.8i axle with lsd ?
Old Dec 1, 2003 | 04:35 PM
escortmad79's Avatar
escortmad79
If you are using the RS2000 engine & box as well as RS back axle then you need to swap the prop also for an RS type as the original is too long for the gearbox & has the wrong size ends.
The RS2000 prop is available as both single piece & split prop
Old Dec 1, 2003 | 06:23 PM
no mate the Capri box has a longer main shaft so will not fit you can either use a sierra 5 speed type 9 or the standard 4 speed you have but the gearing is a bit bad you should be able to pick up a gear box 5 speed quaife for about £650 you will need to get a alloy RS bell housing but like we said before it does involve moving the gear stick hole and mounting back so look for a 4 speed quiafe to make life a bit quicker and easier for you.
As far as 2.8 rear axle goes you will need to get a RS prop with atlas rear flange on it try WWRS they will have one in stock but it does mean more welding and also a set of arches as they are much wider than the axle you have now. Your best bet would be a atlas shaft conversion with a 4.4:1 diff with lsd and a 4 speed box it all depends on what the car is going to do?
Old Dec 1, 2003 | 09:35 PM
fatboyz's Avatar
fatboyz
so if i use a 2.1 pinto type 9 sierra box ( moving gearstick hole back no probs ) maybe my prop with a atlas rear flange can this be one if so how much ? and a 2.8i axle as we will be fitting forrest arches anyway and im a bit handy on me welder i thought this would be good cause strong ish and cheap ish
aaarrrggghhh i thought this would be easy
Old Dec 2, 2003 | 01:08 AM
biglez's Avatar
biglez
I'm in Liverpool,it's £12 to post the prop - I thought the one that is in it has a smaller fornt end on it,therefore wont fit on the splines of the new gearbox?
Old Dec 2, 2003 | 10:31 AM
No they are all the same splines just the rear flange where it bolts onto the axle is diffrent on an atlas rather than an english. If you have a 5 speed box the front flange just goes futher into the box than the 4 speed unit from my experiance.
2.8i atlas axle with a lsd unit is still not cheap make sure that there is an lsd unit in it as they did not come with all 2.8i's.
As for beaing easy nothing in modding a car is easy?
If you look on ebay there are a few peolpe selling preparing a Mk2 escort for motorsport this will give u a lot of needed info yes it is rather old but the princales are the same.
Glad u can use a mig as with any old car you are going to need it. LOL
Old Dec 2, 2003 | 05:02 PM
escortmad79
LSD came on 2.8i specials only
Old Dec 2, 2003 | 10:03 PM
biglez's Avatar
biglez
I've got a prop in my garden shed off a mk 2 1300 with a front end with a smaller diameter and less splines on it,so be careful wot you use
Old Dec 3, 2003 | 09:45 AM
Ah now that could be for a very ealry type 2 gear box with an intergral bellhousing it should have a type E box in it and that does have the same splins and size as the type 9 box.
Old Dec 4, 2003 | 12:24 PM
biglez's Avatar
biglez
I bow to your superior knowledge
155lee
Sep 6, 2016 11:10 AM
mk1turboestate
Dec 2, 2015 08:31 PM
rs_jim
Oct 3, 2015 11:37 AM
IainRS1700T
Sep 25, 2015 06:44 AM
3doorcozmess
Sep 15, 2015 06:06 PM
