Best way to check the oil pressure sender???
for the dashboard light? its just a switch to ground if the pressure drops below 7psi
for a gauge that shows the pressure - the lower the pressure, the higher the resistance and vice versa
for SPA digital jobbies - 4 wires of confusion
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
