T34 or T38 Dyno Graph Please.
sorry doug, figures aswell please. infact there more important than the graph.
should have been more clear.
ok mike the typical t34/63 housing.
and one of harvey spceial t38's
just want to compare some numbers
mike, what conclusions would you draw comparing the 2 figures.
the t34, give a much harder low down punch, but past 4.5, struggle to produce the torque?
the TT38, comes in slightly later, with what seems a slightly less aggerssive surge, but quickly makes power and holds it to the limiter?
very true stu,
but atleast mine are car based and instigate a discussion of sorts,
rather than the usual pointless topics that fill the general discussion.
my toilet fell down the loo
what on TV tonight.
my girlfirend dumped me
my gf a crack hoare
what on TV tonight.
my gf a crack hoare
My conclusion is that the version that Bill has is the BEST compromise between power and cost currently available.
I personally believe that the other T38s on the market are too similar to a T4 in lag to be worthwhile (in fact my own engine with a T4 makes more power lower down AND higher up than YUMs...).
Ryan, wasn't that graph done in 3rd gear?? (Dave's)
I sound all technical here, but actually I think it was the thread with someone slagging the negative lambda
Then Mark came on and explained!!?
Originally Posted by Ryan
..........but atleast mine are car based and instigate a discussion of sorts,
what on TV tonight.
my gf a crack hoare
what on TV tonight.
my gf a crack hoare
"my car is trapped by scafolding all around it, should I break it now and sell for spares?"
doug you cooooooooooont.
scaffolding is all gone as the house is almost done, thanks fook
so i can now press on with the car.
pick the engine up today, and jsut need to get a turbo.
i've been offered a new turbo technics t38, and a very good price, hence why im asking the question.
kev, you and me both
Has the head been flowed & ported?
Standard valves?
Comp ratio?
Cams?
Better to choose a turbo that matches your engine spec......than one that is cheap I would have thought
Originally Posted by kjc300
I hope that's not for me Mike!!!? OR if it is you can have a real one!!!
.I see what you did there!!!
oh and i've looked over daves, and bills engine spec, and fail to see any difference? possibly cams "harvey" specials
oh and dave i spend my money elsewhere. where it matters. not on a toy
