0-100
Old Dec 20, 2005 | 03:18 PM
Staffi's Avatar
Staffi
Default 0-100
hi folks, just wondered if you could give me a rough estimate of what sort of times my car should be getting from 0-100 in,
SPEC. Stage 3. T34, greens, 500 cooler, GRP.Agasket, low comp. mapped by Karl Norris. Just wondered what similar cars were doing it in?
Its a 3 door.............cheers Staffi..............
Old Dec 20, 2005 | 03:21 PM
12 seconds i guess?
Old Dec 20, 2005 | 03:25 PM
heeman10's Avatar
heeman10
You didn't say how much boost??? Could be anything really!
Old Dec 20, 2005 | 03:26 PM
Well he said mapped by karl, so safe to assume 330-350 bhp i guess?
Old Dec 20, 2005 | 03:27 PM
JamesH's Avatar
JamesH
Probably spikes at around 1.9BAR then slowly drops through the rev range and holds around 22psi for the limiter!
Just a guess though!
Old Dec 20, 2005 | 03:28 PM
Staffi's Avatar
Staffi
24psi.............
Old Dec 20, 2005 | 03:29 PM
JamesH's Avatar
JamesH
Should be same as the one in my sig, which Karl said is a good, strong, 350 brake and 350ft/lb torque, give or take 5bhp and 5 ft/lb torque
Staffi's Avatar
Staffi
Well he said mapped by karl, so safe to assume 330-35yes chip Karl reckons about 340 ish0 bhp i guess?
Old Dec 20, 2005 | 03:31 PM
Staffi's Avatar
Staffi
Yes chip Karl said about 340- 350ish.............
Old Dec 20, 2005 | 03:37 PM
heeman10's Avatar
heeman10
Care to tell us what that is then?
Old Dec 20, 2005 | 03:39 PM
JamesH's Avatar
JamesH
Read my post again!
Or the long version is:
All stage 3, so Greens, 500 Cooler, T34, 3bar Map Sensor ect...
Karl reckons it's a good 350bhp and 350 ft/lb torque, give or take 5 each way.
Boosts upto 1.9BAR (27.55psi) upto 5000 rpm, then drops to 23-24psi for 6000rpm, and then tails to (22psi) for the limiter to 7250rpm.
Old Dec 20, 2005 | 03:40 PM
Snowy_Astra's Avatar
Snowy_Astra
My N/A 2 litre 16v redtop pulled my astra to 100 in 14 seconds
Got video evidence too
Old Dec 20, 2005 | 03:46 PM
heeman10's Avatar
heeman10
Smidsy - No I mean your 0-100 time, that's the thread question
Old Dec 20, 2005 | 03:50 PM
JamesH's Avatar
JamesH
Ah right mate, Dunno never done it!
Last time was at the pod was running in the engine still and has only done 600 miles on it, also on my old chip!
Old Dec 20, 2005 | 03:57 PM
Can help a bit from my own car as it developed.
400bhp 10.2s
500bhp 8.8s
570bhp 8.1s
660bhp 7.1s
Thats my own cars progress.
Old Dec 20, 2005 | 04:00 PM
Snowy_Astra
Originally Posted by MADRod
660bhp 7.1s
Old Dec 20, 2005 | 05:01 PM
Spence 14 isnt too bad.
Robs astra did it in 9.something at TOTB juding by the 12.6@121mph, but dont have an accurate time, mid 9s rather than high 9s though though i think as it must take 3 from 100-121.
That was with not much over 350bhp though, so probably under 9 at its best it ever ran on the old spec (just over 400bhp)
Should be well into the 8s now though on the new spec engine im building for him currently
So should be a match in a 0-100 sprint for a 550 bhp cossie based on Rods figures
Fook knows what my mini will do 7.something i hope!
Old Dec 20, 2005 | 05:03 PM
gurnE's Avatar
gurnE
I hoping for mid/low 6s next year
Old Dec 20, 2005 | 08:23 PM
Staffi's Avatar
Staffi
Low 6s........kinhell............
Old Dec 20, 2005 | 09:27 PM
low6s = R1?
Old Dec 20, 2005 | 09:30 PM
gurnE's Avatar
gurnE
low6s = R1?
Not sure yet mate.
Quite like the twin so might go for an RSV Mille, especially as the prices are quite deflated after Aprilia financial problems earlier this year
Pretty much any decent sportsbike will do a sub seven 0-100
Old Dec 21, 2005 | 12:20 AM
Snowy_Astra
What? Robs having a new engine? But but but he cant! I would have had a little advantage over him with mine when shes setup!
Still need a loom and ECU, could you try and rob his for me?
EDIT: Oh you mean Rob SBD16V Rob? *tsk* i thought you meant McFly lol
Old Dec 21, 2005 | 03:54 AM
Benni's Avatar
Benni
Ban[B][/B]ned
400bhp 10.2s
500bhp 8.8s
570bhp 8.1s
660bhp 7.1s
Truly awesome times Got any pictures please mate ?
Old Dec 21, 2005 | 10:47 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Look in the vital stats in Performance Ford
Mines uder 11sec (was timed by Datron)
Steve.
Old Dec 21, 2005 | 01:20 PM
kevmk2's Avatar
kevmk2
My 0-100 was in 8.7 seconds thats with 383bhp on the rollers. And 405bhp on the engine dyno
Old Dec 22, 2005 | 04:48 PM
stevieturbo's Avatar
stevieturbo
C**t
Tyres used, and vehicle weight will also play a huge part.
Old Dec 22, 2005 | 04:51 PM
James-W's Avatar
James-W
Martins new car will do it in the 4s according to cam.
Old Dec 22, 2005 | 04:54 PM
Im skeptical about that, but im sure it will be well into the 5s
Old Dec 22, 2005 | 05:01 PM
Fast Guy's Avatar
Fast Guy
400bhp 10.2s
500bhp 8.8s
570bhp 8.1s
660bhp 7.1s
Excuse my ignorance Rod but is your car 4wd or Rwd? I'd guess RWD from those times as they're slower than I'd expect from 4wd.
Old Dec 22, 2005 | 05:04 PM
James-W's Avatar
James-W
Yeah so am I chip. I think Martin may have a few more tricks up his sleve. Steve Scotts fiest might pulla four aswel.
Old Dec 22, 2005 | 05:29 PM
Fasy Guy, yeah rods is 2wd
Old Dec 22, 2005 | 05:50 PM
Fast Guy's Avatar
Fast Guy
Cheers. I did race that car back in the 90s when it was running 350bhp and high 13s. but I never got to see which wheels were spinning as I was infront til about half way but then my 240bhp lost out Them were the days
Old Dec 22, 2005 | 05:54 PM
Well i assume from that slip yours IS 4wd
Cause is a fecking terrible terminal for anything rwd or fwd doing those times, i was managing those terminal in a fwd nova that only ran 13.3, so to take a second off it MUST have been 4wd i guess?
Especially with a 1.7 60ft
Old Dec 22, 2005 | 06:06 PM
Fast Guy's Avatar
Fast Guy
Yep, it's 4wd, the clue is in the Gtir in red on the slip I don't have enough power for high terminals yet.
PS the car mentioned above isn't the one I have now (in my siggy)
Old Dec 22, 2005 | 08:40 PM
kevmk2's Avatar
kevmk2
All of our cars would do 4 seconds to 100 if we had his money
Makes me laugh all the people who run after him and think hes GOD!
No offence made by that comment but its so true.
Old Dec 22, 2005 | 08:43 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
He meant 4s to 100... Itl be in the 2s to 60...
Old Dec 22, 2005 | 08:50 PM
kevmk2's Avatar
kevmk2
Now corrected
GARETH T
133
Oct 2, 2012 05:19 PM
M K
206
Jan 8, 2007 08:47 PM
Staffi
40
Feb 2, 2006 05:12 PM
15
Sep 10, 2004 09:04 PM
