advice on getting windscreen out..erst
Carefully us a a large flat blade screwdriver from the inside of the car to fold the rubber behind the frame be carful tho its easy to slip and crack the screen, i usually find after going up 1 pillar and along the top the screen will push out.
work up the sides with 2 drivers and push the rubber beyond the body lip...work slowly untill the screen feels loose then wiggle it out from the top to release the bottom edge......refit with some fairy liqid in the seal and a lenth of wire come and see me and i'l show you how
If its a heated screen dont forget to take the interior clock out and remove the screw behind it!!!!!!
Otherwise as your prizing it out, it will crack from top to bottom
Cheers,
M.
Cheers,
M.
mk3ste
Oct 17, 2021 10:09 AM
rsguy
44
Sep 29, 2015 03:29 PM
