wtf's happened to my gearbox!?
Old Dec 19, 2005 | 05:20 PM
ballin's Avatar
ballin
Default wtf's happened to my gearbox!?
fuckin car
giving it some beans in 4th, changed up to 5th then i seem to recall it jolting a couple of times, then I bogged down so dropped it to 4th and carried on.
LOADS of rattling, and clonking; then realised 5th gear had gone..... if you put it in 5th it just revs - no drive.
Then when I got home went to reverse into the drive and can't get it in reverse - gearstick physically won't go in.
any ideas whats happened? selector or gear or what?
Old Dec 19, 2005 | 05:21 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
That'll be the 'box mate, not the selector. Sounds like 'new 'box' time...........
Old Dec 19, 2005 | 05:22 PM
TIFF's Avatar
TIFF
Chasing Radders
Box is Fucked
rs_daz's Avatar
rs_daz
Mines munched too so ya not alone
Old Dec 19, 2005 | 05:23 PM
edd's Avatar
edd
lost some teeth rich, new bernie box 800
ballin's Avatar
ballin
fuckin arse
Old Dec 19, 2005 | 05:32 PM
ballin's Avatar
ballin
i was going uphill so would that confirm what you said rudes?
Old Dec 19, 2005 | 05:38 PM
evander's Avatar
evander
Youll need to take off the side cover of the box and have a look. The fault will be visible I rekon. Its hard to advise what to do without knowing what the condition of these components is like.
Old Dec 19, 2005 | 06:55 PM
flashpoint's Avatar
flashpoint
Welcome to the world of gearbox killing
Steve
Old Dec 19, 2005 | 07:01 PM
ballin's Avatar
ballin
Steve
haven't seen you in AGEESSSSS mate!! hows it going, you efi yet?
how long to get the engine out of a fezzy then?
Old Dec 19, 2005 | 07:33 PM
Ginge !'s Avatar
Ginge !
just finding my feet
good news is you can fix 5th gear easy enough
as rudey said though, thats spot on info
btw i average atleast 1 box a year,,,,,,,,,, and thats on my runabouts, the cossie box is fooked in mine too but the T5 is a trooper and just carrys on going
take off the end and have a play, ive got a box with a fooked lay shaft bearing but its still got 5th on it,,,,,, actually ive got 3 like it
Old Dec 19, 2005 | 07:40 PM
ballin's Avatar
ballin
lol fair enough - can you get the end of in-situ then?
Old Dec 19, 2005 | 07:41 PM
ballin's Avatar
ballin
and when you say 5th is starved of oil first - is that because box oil was low or because I was going up a steep hill?
Old Dec 19, 2005 | 07:49 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
mine done the same earlier this year going to croft. just got it in 3rd gear giving it hell and bang, wheels locked and no gears. Gave no sign of giving up before it went. Stripped box and found twisted and snapped main shaft and only reverse had teeth left
200+ BHP and heavy foot on std box dont go very well
Moondust_crust's Avatar
Moondust_crust
pretty sure the 5th gear oil starvation thing is just a crap ford design, bernie does a 5th gear oil mod to allow loads more oil into the end of the box so it doesnt happen again.......
Old Dec 19, 2005 | 07:56 PM
Ginge !'s Avatar
Ginge !
thats the lay shaft bearing being killed, thats caused by slowing the car down with gears ( its true as thats what i ALWAYS do and ive done prob 7 boxes,,,,,,, NON OF EM IN A TURBO POWERED CVH AND ONE IN A 1300
5th gear is caused by low gearbox oil btw, if the oil level was right then it would still go BUT usually when holding it at high revs for a long period of time,,,,,,,,,, i done 1 box like that but i held the foot to the floor from watford gap services to the leeds turn off and the car just "poped" out of gear and i could get 4th fine, just would not hold in 5th untill i slowed down a little and the box cooled down
that box actually lasted me for 10k miles after that, but never used it on a motorway since
Old Dec 19, 2005 | 07:58 PM
ballin's Avatar
ballin
well if its low oil its even worse cos it could have been prevented
box only went in a year ago
why do you think i cant get it into reverse?
Old Dec 19, 2005 | 08:06 PM
Ginge !'s Avatar
Ginge !
reverse im not totally sure off, maybe the linkage is slipped and the box is fine
and maybe i am REALLY big boned person with strawberry blonde hair
Old Dec 19, 2005 | 08:08 PM
Sean_RS's Avatar
Sean_RS
shit... sounds like is a shit time for gearboxes, mine gone aswell
Old Dec 19, 2005 | 08:13 PM
Ginge !'s Avatar
Ginge !
yeah thats it, its cause its december the boxes die,,,,,,,, if only you left in in the garage till january then it wouldnt have died
Old Dec 19, 2005 | 08:15 PM
Kieron's Avatar
Kieron
Is this in the FRST? Cause thats a Quaiffe box.
Old Dec 19, 2005 | 08:16 PM
Sean_RS's Avatar
Sean_RS
yeah cos thats what i meant...
Old Dec 19, 2005 | 08:17 PM
Ginge !'s Avatar
Ginge !
quaiffe boxes also die when theres no oil in em too btw
just ask sunny
Old Dec 19, 2005 | 08:18 PM
Ginge !'s Avatar
Ginge !
fook me you seem tense
pop out and take the car for a rag, i find that helps me when i feel grumpy
Old Dec 19, 2005 | 08:19 PM
Sean_RS's Avatar
Sean_RS
pmsl i would do if my gearbox wasnt fucked
Old Dec 19, 2005 | 08:40 PM
ballin's Avatar
ballin
Kieron yeah mate be interested to see the fluid level can't believe its low as it got installed properly afaik only last year
Old Dec 19, 2005 | 08:42 PM
Ginge !'s Avatar
Ginge !
balin when you fill the box you have to leave it for 20 mins then refill as the oil gally to5th takes a while for it to tget through,,,,,,,,, i know thats no use now though
Old Dec 19, 2005 | 08:51 PM
Kieron's Avatar
Kieron
Sorry to hear that mate. The fluid level in the box was definately OK.
I remember well as Steve gave me a gearbox oil dirty shanchez.
Old Dec 19, 2005 | 09:03 PM
ballin's Avatar
ballin
pmsl....
did you do the work on it then? didn't realise you knew the car
Old Dec 19, 2005 | 09:18 PM
Kieron's Avatar
Kieron
I didn't do much on it, helped change the box, mounts, Anti rollbar and fitted the cossie brakes up front. Most of the engine work etc was done by EA.
Know the car well
Can't see why you are selling it mate.
Old Dec 19, 2005 | 09:21 PM
EssexBoyRacer's Avatar
EssexBoyRacer
I got a bernie stage 2 box for sale
Old Dec 19, 2005 | 09:32 PM
ballin's Avatar
ballin
bit of a spur of the moment thing i spose mate, but I need a car for work and now im fucked.....its xmas, wont be fixed until new year etc. just cant be dealing with it lol
might change my mind once i get started on it dunno!
Old Dec 19, 2005 | 09:36 PM
Kieron's Avatar
Kieron
Know the feeling, two cossies and I am still having to drive around in a damn pug!
Old Dec 20, 2005 | 12:41 AM
heeman10's Avatar
heeman10
Ballin - I have a full ERST 'box stripped back home, everything bar the LSD. If you want fifth gear alone let me know. I have a Stage 1 Bernie 'box in my Zetec Turbo Fiesta, and made damn sure it was full! Put the car on axle stands, filled it to the brim, left it half an hour and filled it again, probably took close on 500ml extra after that Had it jacked up to get as much in there as possible.
Old Dec 20, 2005 | 06:42 AM
ballin's Avatar
ballin
dont want to overfill it tho either do ya mate?
cheers for the offer btw. I may well take you up on that! but it will be new year until I can get into it!
Is replacing 5th gear a diy job or do you need to check clearances etc. etc.?
Old Dec 20, 2005 | 08:50 AM
gearboxman's Avatar
gearboxman
Originally Posted by * Rudey *
couldnt say for sure mate but if your box was low for starters it may not help, the dude i worked for said people dont realise they have to check the levels in the box i didnt untill he said i know that
You are bang on the money mate! Unfortunately just about all service schedules I've seen, especially the Ford ones, do not specify "Check gearbox oil level"!!!
Incidentally, the reason the gearbox won't go into reverse is all the 5th gear shrapnel getting in the way!
Old Dec 20, 2005 | 10:25 AM
heeman10's Avatar
heeman10
Not sure you can overfill them really? Sure Bernie would be the one to clear that query up I'd guess if fifth has showered bits everywhere the 'box could maybe do with a fairly extensive strip to clean out the shrapnel. Anyway, if you want a cheap gear, let me know via PM on here or fiestaturbo.com, FT being the better bet
Old Dec 20, 2005 | 10:34 AM
John Laverick's Avatar
John Laverick
Mine did this on the way to National Day this year....worked fine apart from nothing in 5th gear....and it ratttled its tits off
I had to drive the car out of the show car area with 100's of people about with the box sounding like it was about to drop out
