big boost to early
hi troopers,
ive bought a series 2 in 6 different shades of red and whilst trying to do half a dozen maintainance jobs on it i thaught id see if any1 had any ideas on what my turbo is doing for when i get round to the engine.
it starts boosting at 1900 revs and obviously cannot get any power down, is also creating a flat spot mid range,its defo a t3 so please dont ask that lol, somebody has suggested ignition/timing and ecu set up. as its my 1st esc turbo im not up on these things.
hope to see some of u at the manchester rs owners meets, keep your eyes out for the patchwork quilt
cheers
cheers
hi zoober tis danny, from work, the best thing you can do as suggested above is to get it setup. i still not fixed me bloody indicators
going to sparky tomorrow you in work 2day?
Big Boost!! How big?
Its possible your wastegate has seized closed, fairly common on these cars.
Take the Actuator arm off from under the turbo and make sure the wastegate is moving freely.
The wastegate being seized will make the turbo boost very high and then hit Over Boost, which will make the car cut out for a second and nose dive before coming back on.
Matt.
Matt.
thanks for that 1 that sound very familiar. ive got a -31 for it so perfect time to check it out. thats after mending my wing mirrors after the warrington chav maffier keep kicking my wing mirrors off.
naughty chavs
naughty chavs
yes its a patchwork quilt, im now called lionel as in snoopy and friends
u sound jealous, dont be lol
danny check your private messages, ive left my cpw addy, and ill check tnite wether my mates up for that swap with the cossie wheels!
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
boositng at under 2k, your lucky mates most RS's are 3K and above
