How can you tell if a turbos on its way out???
as above!!! it dosnt smoke on boost only when i back off. a friend thought it could be turbo oil seals... anyone got any ideas???
hi... cheers 4 reply. theres smoke but not massive amounts...i have got a t3 on mine dunno if that makes much difference. there is a bit of play in the shaft. wots your veiws on havin turbos reconditioned??? cant realy afford a new 1 at the mo.
my seals are gone on mine she did smoke quite a bit then i topped her oil up and she dont smoke as much i got a seals kit for the t2 but its only tempary(sp) im gona get a t3 conversion soon
The guy's feed back is not that good but if you picked it up it should be ok
http://cgi.ebay.co.uk/hybrid-turbo-T...QQcmdZViewItem
deffo shagged, blow back is the early signs of seals going get it changed mate.
JRS my t2 jammed for a split second on the motorway at 120mph on full boost (8psi)
it just jammed then released dead quick resulting the following day with blow back then constant smoke.
JK12
33
Apr 26, 2021 12:09 PM
