2wd sapp fan switch fit a erst s2?
Old Jul 14, 2004 | 12:28 AM
Hardeep_Singh's Avatar
Hardeep_Singh
Default 2wd sapp fan switch fit a erst s2?
Hi just wanna know the answer to the above question as mine stopped working today which ment i had to by pass the fan switch to get the car home.
i've heard that a 2wd sapp cossie one will fit and they come on earlier then the s2 ones is this true?
Cheers,
Hardeep.
Old Jul 14, 2004 | 04:52 AM
Wazzzer's Avatar
Wazzzer
Yeah I think they come on at a lower temp, someone gave me this finis code, anyone like to tell me and Hardeep if it was right?
7001614
Old Jul 14, 2004 | 11:36 AM
Wazzzer's Avatar
Wazzzer
Old Jul 14, 2004 | 11:51 AM
Hardeep_Singh
com'mon people someone must know?
Old Jul 14, 2004 | 11:52 AM
adamS2RST's Avatar
adamS2RST
7001611 - is what I just used in mine, think this is the S2 one however, but it seems to come in earlier than my last one did before mine went tits up also, luckily I was on my driveway
Old Jul 14, 2004 | 05:12 PM
Stoo's Avatar
Stoo
Sure it was a 4x4 Saff when i bought mine...
Will check for you
Old Jul 15, 2004 | 02:32 AM
Hardeep_Singh
wes RS - yep thats the finish code for the 2wd fan switch, i know this as i went to fords today and bought one only Ł9
Old Jul 15, 2004 | 04:16 AM
Wazzzer's Avatar
Wazzzer
Nice one, will be popping down there myself 2moro then
Old Jul 15, 2004 | 10:45 AM
wildheart's Avatar
wildheart
Dont know about the 2wd one but the 4x4 fan switch comes in earlier and is a straight swap.
Old Jul 15, 2004 | 10:47 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Yeah, 4x4 I heard, not 2wd
Old Jul 15, 2004 | 10:57 AM
DOO's Avatar
DOO
2wd and 4wd cosworth use the same switch 7001614 Ł8.36 +vat
Jon ERST S2's Avatar
Jon ERST S2
Anyone got the finis code for this?
Old Jul 15, 2004 | 11:26 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Yes jon!
Originally Posted by DOO
7001614 Ł8.36 +vat
Old Jul 15, 2004 | 11:32 AM
Jon ERST S2
lol same post time
So 4x4 DOESN'T kick in earlier?
Old Jul 15, 2004 | 12:13 PM
Wazzzer's Avatar
Wazzzer
4X4 and 2WD fan switch kick in earlier than the standard RST one
Old Jul 15, 2004 | 08:23 PM
Hardeep_Singh
fitted my 2wd fan switch today lads and it comes on ALOT earlier then a standard ERST one, it comes on between 77-86 degrees which is what it says on the side of it, IMO i wouldn't get one that comes on any earlier as you will find youe fan will never switch off lol
about the 4x4 one i dont think that will work as i heard it is a 2 stage switch or something.
Cheers,
Hardeep.
Old Jul 16, 2004 | 06:11 AM
Wazzzer's Avatar
Wazzzer
Excellent, that and my kenlowes and 82deg thermostat and it should run a lot cooler
Oct 9, 2015 07:38 PM
mrmann
Aug 20, 2015 11:24 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
lockie
Jul 31, 2015 10:03 PM
