Denso Sparkplugs........
Team HOTHOT!
As a few of you will know, i run Denso Irridium IK31 plugs in my car
anyway, on the way to the blackpool pissup last week, i noticed a small misfire when accelerating in 4th and 5th and a bit of unburnt fuel out the back.
upon inspection today of the sparkplugs, 2 of them (numbers 3 and 4) had showed signs of a heat related failure.
#3 plug = the insulator was slightly loose in the body of the plug
#4 plug = the whole insulation was freely spinning round inside the plug and carbon had blown up the middle of the plug
This also happened when running IK27's in germany aswell on one plug, but on a different cylynder (number 1)
has anyone else had any problems with running these plugs - IK27 or IK31 in their cossies? as at 40 to 50 quid a set, they are bloody expensive to only last 4000 miles
Team HOTHOT!
and before anyone says "get your car set up" or "you car isn't set up properly", the car was setup by Stu before we went to germany and has absolutely NO problems at all apart from an appetite for 50 quid plugs
PassionFords Creator
Need to be looking at the fuelling Gracie, something may well be amiss with it somewhere now since we did it. I have customers with FAR bigger power than yours running these plugs with no problems at all, including my own which at a guess have covered over FIFTEEN thousand miles now pal!! You must have done a good few thousand since i saw you?
Team HOTHOT!
this is true Stu - may be time for me to buy a set of them there black injectors from yourself as i'm sure the greens can't handle the top end fueling - as the ik27 only failed after that 150-160mph blast down the autobhan on the way home
Originally Posted by jaycos
this aint the first time ive heard this on denzos , stu recomended 071cs ages ago to me and thats wats in there spot on , save ya cash man .
jay
jay
jay
jay
cheers jay
Originally Posted by BlueSmoke
Paul your car is one temperamental mofo.....
What happened with that power steering fluid you found under the car in Blackpool by the way?
why are people spending £50 + on plugs when harvey uses rsturbo ones (
<-- real tears ) in his 400+brake engines????
<-- real tears ) in his 400+brake engines????Not to mention the fact the unburnt fuel at part load measurable in the exhaust almost HALVES on most YB's with the Iridiums fitted?
Originally Posted by b19bal
701's mate
speak to alexzvhcabrio ( also ask him to shorten his user name soo
he might still have some left
)he might still have some left
Still owe him the bucks for them aswell.....D'oh!
well, when I asked him.. and mentioned the more fruitier of plugs.. i was told not to bother as the rst ones were more than good enough
I personally would love to junk the rst ones.. brings me out in a rash, just from firing her up!
The plugs are used in lots of jap motors without problems (under various guises including HKS)
so i am fairly sure the plugs wont be the problem. Having said that i have not had any experience with them in the sierra though.
The 071s are a great plug for the YB but they dont last very long (Relatively speaking) and they arent the best with extremely lean mixtures (Leaner than 15:1) Other than that, fill your boots, great plug and VERY strong indeed.
Remember, when running a wasted spark configuration your plugs last less than half as long as they do with a conventional distributor cap
I dont need it now im bald anyway
I sell and run Denso's mainly for Jap stuff, but I have had no problems with the Cossy applications.
I use the vk20pr-z11 as should the 4x4 saff's
T34 should run svk20r-z8
2wd saff are ik24
rs500 are ik27
3dr are ik22
With no cat on the car different plugs need to speak to your tuner.
Sometimes it is important to change the heat range when running higher boost etc, i.e. use a colder plug i.e. go from vk20pr-z11 to vk22pr-z11, or from a ik22 to a ik24 etc etc
Escort turbo runs ik24 and tuned ik27.
2wd saff are ik24
rs500 are ik27
3dr are ik22
I Just got some IK27 ones for the cossie, as Mark said they are the ones! Didnt pay £60 more like $50 lol so will soon see what they are like. But no dought they will be proper if Mark recommended them and also stu says there top
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Si B
Sep 12, 2015 06:49 AM
oilman
21
Oct 3, 2005 11:15 AM
