Diff Ratio's.... knowing what they are!?
Old Dec 18, 2005 | 08:40 AM
Kelv's Avatar
Kelv
Almost there!
Default Diff Ratio's.... knowing what they are!?
is there any quick and easy ways to tell what ratio a diff is?
in reference to a 4x4 front diff, with sump plate removed. would just be handy to know exactly what it is!
Kelvin
Old Dec 18, 2005 | 08:47 AM
croppy's Avatar
croppy
something like count number of teeth on the crown wheel and devide it by the number of teeth on the front pinion
i sure thats it
check the edge ov the crown wheel on the early mk1 mk2 diff it was writen on crown wheel
Old Dec 18, 2005 | 08:48 AM
Mark V8's Avatar
Mark V8
Count the teeth on the crown wheel and divide that by the number of teeth on the pinion
Mark
Old Dec 18, 2005 | 08:50 AM
croppy's Avatar
croppy
so i was right
Old Dec 18, 2005 | 08:51 AM
focusv8's Avatar
focusv8
If you can see the Crown wheel (big gear) and Pinnion (small gear),
Count the teeth on both gears:
Ratio = Crown wheel divided by pinnion.
Other wise jack up one side, so the other wheel is still on the ground, (if its L.S.D jack up both sides) turn road wheel 1 rev and count how many revs and part revs prop shaft turns = Ratio .
Tooo slow posting
Old Dec 18, 2005 | 08:53 AM
Kelv's Avatar
Kelv
Almost there!
The Diff is currently out of the car so can be counted on a bench.
will have a look and see how i get on...
... Cheers
Old Dec 18, 2005 | 09:15 AM
Ryan's Avatar
Ryan
you should have left by now
Chas
Sep 21, 2015 08:57 PM
mattman1234
15
Aug 14, 2015 10:05 PM
Gadget
Aug 13, 2015 08:19 PM
S3an
Aug 11, 2015 07:26 PM
COLEYST200
Aug 3, 2015 08:55 AM
