Possibly the hardest part i have had to try and get.........
Hi folks
Been trying for about 3 weeks now to try and get the following part with no luck, can anyone help me out ?
On the Series 1 Turbo, on the bottom of the fuel filler neck pipe, there is a section of rubber hose thats about 8-10 inches long. Its jubilee clipped at one end onto the filler neck into tank pipe, and the other end onto the fuel tank filler hole.
It was only £13 from Fords, but surprise surprise no longer available.
If anyone has one kicking about can you PM me please ? Am starting to lose hair with the stress of trying to find one
Its the crappiest little bit ever, but causing me grief. I have found one or two on breaking cars but both have been cracked and leaking so no use.
Anyone got one ? Pleeeeeeeeeeeeeeeeeeeeese
Many thanks in advance folks.
Michael
Michael
I have the part you need mate..
Send a SEA to me and ill return you the pipe free.
I dont use the std pipe in this place as they all have the same problem after a while..
Regards
Jano
markyd3
Regards
Jano
markyd3
I cant be bothered to ask for £1 for a bit of pipe mate..
I send out loads of things every week for people without charge just to get rid of them.
Breaking cars leaves loads of shite parts that no-one wants untill you throw it away
So i end up keeping it all for years and years and years..
Last week i sent:-
1 Thermostat plug and length or wire.
1 throttle body ERST
2 water pipes
some bolts and clips
I had a couple of peeps come down and pick up heater box and headlining plastic bits and pieces aswell
Dont get me wrong i do sell items but only if its worth asking money for.
So i end up keeping it all for years and years and years.. Last week i sent:-
2 water pipes
NO
you cant have it!
Maybe for a small sum of £ id be able to supply a fully worked mountune engine with WRC head (Oversize water & oil ways, extra water ways in core plugs etc..)
P&P Free
you cant have it! Maybe for a small sum of £ id be able to supply a fully worked mountune engine with WRC head (Oversize water & oil ways, extra water ways in core plugs etc..)
P&P Free
Cheers Jano will send an envelope on monday, can you PM me your address please ? Thanks a lot.
Its the fuel filler one XR4X4S, not the breather one. The breather one is slightly less of a bore size.
155lee
Sep 6, 2016 11:10 AM
Fudgey
Sep 17, 2015 01:06 PM
