cosworth relays
Old Jul 13, 2004 | 07:56 PM
Moose 130's Avatar
Moose 130
Default cosworth relays
On the engine loom of a cossie there are 2 relays near to the ecu.
is there anything special about them? or are they normal 3 pin relays?
I have a loom but no relays and don't fancy paying cossie tax if they are nowt special.
Old Jul 13, 2004 | 10:03 PM
Moose 130's Avatar
Moose 130
up, until I get a knowledgable answer.
(and on here that might be some time!! )
Old Jul 13, 2004 | 10:13 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
just pm pete or paul north yorks and theyll sortem ya
Old Jul 13, 2004 | 10:15 PM
DazC's Avatar
DazC
A 3 pin relay would be a flasher relay!!!!????
The 2 near the ECU are 40 amp relays for the ECU ignition feed, in jector feed and the other is fuel pump, amal valve and idle speed control valve...
Not sure on the pin configuration but it is possible that they are Ford unique but not Cossie unique.....(Ford just changed the pin configurations round over a standard relay)
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
15
Oct 7, 2015 03:43 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
