Cossie throttle body onto EFI manifold
Old Dec 14, 2005 | 04:51 PM
Moonie's Avatar
Moonie
Default Cossie throttle body onto EFI manifold
Im in the process of converting my Escort to EFI, i have the inlet manifold (fiesta) and i am just waiting for the throttle body. Has anyone any advice on fitting a cossie throttle body to the manifold?
I have been told that the bolt pattern on the cossie body is larger, is it just a case of building up the alluminium with ally weld and drilling/tapping new holes?
Which is the best way round to mount the throttle body?
Which throttle cable to people use and where/how do you secure the outer cable to - one off bracket or is their an easier way?
Thanks for any advice.
Old Dec 14, 2005 | 07:00 PM
adamS2RST's Avatar
adamS2RST
Gadget or Jano should be able to help
Old Dec 14, 2005 | 07:26 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
throttle cable at top iirc!
And you'll need the top left ( facing the throttle body ) built up with weld, then drilled and tapped
jessie_rs
62
Aug 6, 2019 09:27 PM
dombanks
Sep 21, 2015 08:38 PM
RSmark84
Sep 13, 2015 01:29 PM
Marino
Sep 12, 2015 11:10 AM
bigryrs
Sep 7, 2015 06:45 PM
