stage 1 superchip... problems!!!
Dec 14, 2005 | 08:47 AM
hi people!!! i have just fitted a stage 1 superchip and i think its fucked. the car runs fine for about 15 mins then if i rev any higher than 3000rpm it has no power and sounds like its overboosting or misfiring. i took the chip out and it runs fine again. i got the chip from e-bay its not new. has anyone had the same problem or knows what could be causing this to happen?
Dec 14, 2005 | 10:48 AM
You could have bought a knackered chip. To be honest, Ebay is not exactly the best place to go buying chips.
Dec 14, 2005 | 11:07 AM
thanks for reply... i think your prob right.
Dec 14, 2005 | 11:19 AM
Daft question time - is it the right chip for your ecu?
Dec 14, 2005 | 11:30 AM
yer ofab ecu and ofab sticker on chip. i cant understand how it can work for bout 15mins then start flippin out?!?!?!
Dec 14, 2005 | 11:39 AM
Sorry but def sounds like a dodgy chip your best of going to get one fitted and the car set up at the same time
Dec 14, 2005 | 11:42 AM
In the first 15 minutes can you go above 3k rpm?
Dec 14, 2005 | 04:17 PM
Yeah it drives perfect,its like a fuckin rocket!!!
Dec 14, 2005 | 05:26 PM
What stage chip is it and how did you set the boost?
Dec 14, 2005 | 05:30 PM
its a 165 stage 1 superchip... turned boost up on the -31... only boostin at 13psi holdin 12.
Dec 14, 2005 | 05:39 PM
I'm wondering if you're getting boost creep or the gauge you used is reading low and you are hitting the overboost protection. Try winding the boost down a couple of psi and see if you get the same problem.
Dec 15, 2005 | 04:55 AM
i will give it a go mate.... cheers!!!
Dec 15, 2005 | 11:10 AM
if the chips fu#ked does anyone know if they can be reprogramed or fixed???
Dec 16, 2005 | 06:21 PM
If the chip's had it I doubt if it can be repaired, the're usually encased in resin to stop people taking them apart.
Any joy with winding the boost down?
Dec 16, 2005 | 08:32 PM
i dont realy know how to change the boost settin... a mate does all the work on my car... iwill let you know how it goes when hes done it.
JK12
33
Apr 26, 2021 12:09 PM
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
Flateric_2002
Sep 15, 2015 08:41 AM
tib2220
Sep 14, 2015 12:33 PM
