advice needed
Old Dec 13, 2005 | 04:43 PM
jonnyfrst's Avatar
jonnyfrst
Default advice needed
my car has a flat spot when you come on boost the car sort of holds back and won't accelerate. it clears up at after the about 10sec's and goes like stink.
it gets worse in higher gears
it holds boost fine.i must find the fault soon cos i'm going crazy
i had put the car in for a tune up and got told they have taken ma dump vavle off and it seems a little better but still the same
do use think it is the turbo thats gone or any ideas folks would be great
Old Dec 13, 2005 | 04:45 PM
addiction's Avatar
addiction
did you have a tune up or a proper set up on the rollers?
Old Dec 13, 2005 | 04:46 PM
jonnyfrst's Avatar
jonnyfrst
a set-up on the rollers ther have been working on it for 2 hours
Old Dec 13, 2005 | 04:48 PM
addiction's Avatar
addiction
a good tuner will find the problem dude
Old Dec 13, 2005 | 04:50 PM
jonnyfrst's Avatar
jonnyfrst
but i think the guy who was working on it is a cowboy and will rip u off mate thats why im trying2 see what others think
Old Dec 14, 2005 | 01:35 PM
andre_k's Avatar
andre_k
who was it? why waste money if you think theyre cowboys...
why would it be the turbo?
take it to someone good
Old Dec 14, 2005 | 02:03 PM
jonnyfrst's Avatar
jonnyfrst
falkland performance
i have been told there is a crack in the turbo
Old Dec 14, 2005 | 02:27 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
get it to AVA. . dont waste time or Ł anywhere else.
could be a boost hose collapsing under load.
are they std or samco?
Old Dec 14, 2005 | 02:31 PM
jonnyfrst's Avatar
jonnyfrst
its got a samco boost hose on it and i was told i cant run a dump valve on ma car for some reason but not told why
Old Dec 14, 2005 | 02:34 PM
dexterc's Avatar
dexterc
*Runs for cover before the dump valve ruck starts again*
The main reason, aside from hating the sound, is that the engine hates air leaks, which is exactly what a dump valve introduces, and the pressure isnt enough to need one, as it wont damage the turbo.
Old Dec 14, 2005 | 02:37 PM
jonnyfrst's Avatar
jonnyfrst
but surely it would be the dump valve making the car do what its doing when it comes on 2 boost
Old Dec 14, 2005 | 08:32 PM
zippyobrien's Avatar
zippyobrien
is your cam worn?
Old Dec 14, 2005 | 09:02 PM
jonnyfrst's Avatar
jonnyfrst
everything in the engine is all new just been in it for 2months
Old Dec 15, 2005 | 05:07 AM
stevedb's Avatar
stevedb
hi mate... i get the same problem with mine. it really pisses me off. have u found out wot it is yet???<escort cab... efi frst engine>
Old Dec 15, 2005 | 07:26 AM
jonnyfrst's Avatar
jonnyfrst
still not found out yet mate but hoping 2 get it into AVA before the weekend 2 see if we can find out whats up
Michael Wisbey
Aug 14, 2015 11:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
