Engine mods
Old Jul 13, 2004 | 01:38 PM
cosworthbg's Avatar
cosworthbg
Default Engine mods
Hi,can anyone tell me what's the max power I can get with T34 on my cossy?What injectors,pistons,camshafts,headgasket etc.etc. do I need for such upgrade?
10x in advance
Old Jul 13, 2004 | 02:19 PM
Disabled Account's Avatar
Disabled Account
Default Re: Engine mods
10x in advance
If it is a standard T34 the max would be 370 - 380 BHP, you will need Light Blue or Grey injectors. My view is that it is best to stay with standard cams but the head gasket should be changed to Cometic or better still O ring the block and fit the LATE Es Cos h/gasket (akaik) YB 1261 + chip and r/r session or live maping.
If you can fit a Hybrid T34 (360° bearing) then the limit is nearer to 400 - 420 BHP absolutely maximum! Then more or less the same spec as above BUT a ported head would now be worthwhile, you now need to fit GREY injectors and a 500 style inter cooler would also be a damn good idea!
Old Jul 13, 2004 | 02:33 PM
wimwerf's Avatar
wimwerf
as above, but a WRC headgasket is good also. and don't forget a stud n nut kit like ARP.
Kyle Langford
27
Aug 5, 2019 07:54 PM
mrknifey
Aug 30, 2015 11:48 AM
SteveyDee
Aug 24, 2015 05:43 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
