Holding Back, Sounding like a Scooby & Backfire like ALS
Old Dec 10, 2005 | 06:00 PM
Default Holding Back, Sounding like a Scooby & Backfire like ALS
my s2 when i start it up for the 1st time of the day. my car is hard to start and runs lumpy when i rev her up as if she aint running on all cylinders. if i hold it at 3k it sorts it self out. i then drive it when i come on boost normally in 3rd gear it will hold back and sound like a scooby sometimes it will backfire quit loud and pop and bang like ALS . once its done that its fine for the rest of the day. but it does this everyday.
any ideas?
cheeRS
Rob
Old Dec 10, 2005 | 06:20 PM
Wazzzer's Avatar
Wazzzer
Old Dec 10, 2005 | 06:50 PM
thunda's Avatar
thunda
maybe its just cold
Old Dec 10, 2005 | 07:17 PM
JayRS2000's Avatar
JayRS2000
mates did sumthing similer then changed to champoin plugs and never had the missfire problem again
just a thought
Old Dec 10, 2005 | 11:31 PM
sufsRS's Avatar
sufsRS
distributor is quite a common fault its worth checking
Old Dec 11, 2005 | 05:07 PM
cheeRS everyone
Old Dec 11, 2005 | 06:34 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Mine does very simmilar, my plug leads are fooked so i thought it might be them as ive got brand new ngk plugs.
Old Dec 11, 2005 | 09:10 PM
Rick's Avatar
Rick
if its not been run for a while then u should put new ford plugs, leads, rotor arm and dizzy cap on.
Timing also may be retarded.
Old Dec 11, 2005 | 09:33 PM
zippyobrien's Avatar
zippyobrien
both ,my turbos do this for the first few minuets of running when there really cold.
Old Dec 11, 2005 | 10:11 PM
AKRS1's Avatar
AKRS1
whats ALS
Old Dec 11, 2005 | 10:25 PM
dave_y's Avatar
dave_y
Anti-lag i think
Old Dec 11, 2005 | 11:33 PM
vroooom ptssssh
It Wasnt Me!
Yep ALS is Anti Lag System
Old Dec 12, 2005 | 12:51 AM
its runs everyday mate. i had it set up a few months ago and changed my plugs about 1 month ago. so its a bit wierd lol
Old Dec 12, 2005 | 11:05 AM
Rick's Avatar
Rick
Ok, id defo check the dizzy cap though - any moisture in there is a no no. It actuallyu sounds like it's over fueling - have u got the cold start injector connected?
Old Dec 12, 2005 | 03:53 PM
i'll do that mate yeh i have got it connected. worth taking off?
Old Dec 12, 2005 | 03:56 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
yeh it is rob, if you dont know how, i'll pop round and do it
Its on the underside of the back of the inlet manifold
Old Dec 12, 2005 | 04:03 PM
andre_k's Avatar
andre_k
mine does the same (startup misfire), just had new plugs, leads, cap, arm, setup @ Pramsport...
When i told jamie, he said it could be the injector seals...
worth a shot maybe? there were some on ebay a while back for cheap...
Old Dec 12, 2005 | 04:07 PM
bloody cars
cheeRS peeps nice one Rad
Old Dec 12, 2005 | 04:08 PM
Charlie Chalk
Unknown.
smiley
Aug 16, 2015 06:36 PM
track.focus'd
Aug 12, 2015 05:53 PM
Adam-M
22
Aug 10, 2015 10:46 AM
blakey100
Aug 4, 2015 08:17 PM
