Front mounted intercoolers
So you just cut the two sides away and at the bottom then do you fibre glass where you have cut away? Or just use body filler? or both?
Thanks,
James.
Thanks,
James.
dont do it!!!!!!!!!!!
just trim the top and bottom bits but leave the centre large piece in place.that way the car will look better with the number plate in original place
When you have done the cutting what is the best way to finishs it off??
Car body filler ??? Do you have to fibre glass first where u have cut??
Jim.
Jim.
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
Escortdriver1
Aug 19, 2015 09:02 PM
