problem ( clonking noise) 4x4
Old Dec 8, 2005 | 03:55 PM
Fil's Avatar
Fil
ELASTIC BAND
Default problem ( clonking noise) 4x4
rear of car drivers side @ 1mph a clonk that gets qiucker with speed until 30ish then cant hear it (PROBABLY DUE TO EXHAUST)
dont do it when rolling 20 to 0mph with the clutch down?
now ive got it jacked up no wheel bearing play,
the drive shafts should move in and out long ways slightly? am i right?
but not up and down atall? if so there seems to be some up and down play in the side the noise is?
does this seem right, am i correct in whats said?
cheers
Old Dec 8, 2005 | 03:58 PM
ryan_belfast's Avatar
ryan_belfast
Check all drive shafts, including the front joint make sure they are all greased up ta fook!
Mine started out like this, then was doing 150mph and the whole thing blew off and took the sump,gearbox,clutch,prop, diff etc all with it...was a mess...
Old Dec 8, 2005 | 03:59 PM
Graceland's Avatar
Graceland
Team HOTHOT!
i bet its the front prop hitting the exhaust downpipe
Old Dec 8, 2005 | 04:00 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Fil - the driveshafts do move in and out yes - this is due to the free space becomeing less between the hub and the diff when the wheels get further into the arch at the back
Old Dec 8, 2005 | 04:14 PM
Fil's Avatar
Fil
ELASTIC BAND
nope its at the rear, only started doing it thismorning
Fil's Avatar
Fil
ELASTIC BAND
thats what i though, but should there be any up and downwards play atall?
Old Dec 8, 2005 | 06:23 PM
xr4x4x24's Avatar
xr4x4x24
I drive a Volvo!
Mine was clunking from the rear, it was the hex headed bolts on the inner cv joint had come loose! Tighten them up, was ok!
Old Dec 8, 2005 | 06:55 PM
Fil's Avatar
Fil
ELASTIC BAND
Nope mine aint loose, dreeding the task of trying to undo them really dont think ive ever had them off on this car
Old Dec 8, 2005 | 07:01 PM
rssapphowner's Avatar
rssapphowner
check your rear calipers as i had this problem and found that one was sticking
Old Dec 8, 2005 | 07:58 PM
Neil S's Avatar
Neil S
Could be the heatshield between the box and exhaust catching on the prop
Mine did this recently till I beat the shit out of it
Neil.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
CossieRich
30
Sep 8, 2015 10:08 PM
Churtz
15
Aug 13, 2015 06:40 PM
Archiejay
Aug 12, 2015 12:07 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
