OIL PRESSURE GAUGE
JUST BOUGHT OIL PRESSURE GAUGE 2DAY (ELECTRIC PSI )CAN I USE THE WIRE THAT GOES TO ME OIL PRESSURE SWITCH TO WRK IT,OR HOW DO I DO IT
i got one of these, you need a 3 way adaptor which you can get off burton power/performance (bout £3)?
you unscrew oil feed pipe (braided one) and fit the 3 way adaptor and screw your pressure sender (one that came with gauge) and your oil feed line into it. will take a picture of my setup if you want.
then you wire it to the back of the gauge.
get some silicone sealant or something to put on the thread when tightening it back up or you will get leakage!
you can try but it probably wont work!! wouldnt advise on the 3 way adaptor that uses the turbo feed idea,go for a 2 way one and use the original switch so you can keep the dash light,the gauge sender and the original switch will go into the adaptor. use PTFE tape on the threads so it seals. but all this is usless if you dont have the proper sender
320 bud , have a word with graham and ask him to put u on to carl, he will be able to fit it for ya bud as hes got one in his car . for a nomminal fee id say , bud , should take him like 15 min matey
DOING ME SELF ANIT A PROBLEM JUST WANT 2 NO WERE I NEED TO PUT IT THOUGHT IT WAS GOING TO BE A SIMPLE JOB BUT AS USUALL ITS TURNED TO SHIT
LIKE EVERYTHING ON A RS
STOP THE CLEVER REPLIES EVERY1 NEED A LITTLE ADVICE NOW AND THEN NO MATTER HOW MUCH U KNOW,ONLY ASKED A SIMPLE QUESTION IF ID OF GOT INSTRUCTIONS DONT YA THINK I WOULD HAVE READ THEM!THOUGHT IT WOULD BE A 5 MIN JOB WIRING IT IN BUT I GUESS NOT
ring Burton Power or Nomad Racing and tell em what make it is and they should be able to sort one for you mate.
http://www.nomadracing.co.uk
https://www.burtonpower.com
