Belive EFI is the way4ward?
Old Dec 6, 2005 | 09:23 AM
Ezzy Danny's Avatar
Ezzy Danny
Default Belive EFI is the way4ward?
Belive i need to swap over to Efi as a good modification for various reasons (able to change injectors, good chatter, power etc) but can anyone tell me where i can get the full setup? i have the fly wheel fitted already (the one with th holes in). Also what is it going to cost me? any help would be greatly appreciated
Old Dec 6, 2005 | 04:08 PM
Moonie's Avatar
Moonie
How much it will cost and where you get it set up will depend on what management system you go for.
Old Dec 6, 2005 | 04:09 PM
Ezzy Danny's Avatar
Ezzy Danny
any1??????????????
Old Dec 6, 2005 | 04:10 PM
Ezzy Danny's Avatar
Ezzy Danny
Efi and cossie management ? does that make sense?
Old Dec 6, 2005 | 04:27 PM
ze-vh phil's Avatar
ze-vh phil
right fella, the most expensive part is your chip and injector package.
this is 660 quid from area- six
might sound dear but its not really when you think of the power you will gain.
xr2i inlet manifold from scrappy, 30 quid or so.
fezzy turbocross over pipe 10 or so, scrappy again.
adaptor plate to mate the inlet to the head 25-30 quid area-six
ofab ecu could cost anything upto 150 quid
i fitted a full 90 spec xr3i loom to my car, 100 quid posted from a scrappy
or buy a fezzy turbo and brake it, use what you need then shift the rest on here.
in my opinion its as good as cossie managment, i've had no trouble with it
thank you mr howell
Old Dec 6, 2005 | 06:26 PM
Lee @ Fusion's Avatar
Lee @ Fusion
Ł40 for loom , EFI inlet and a chip from area 6 or MSD then injectors
lookin at Ł450-Ł600 ish ,
Old Dec 9, 2005 | 04:04 PM
Ezzy Danny's Avatar
Ezzy Danny
NICE ONE GUYS
Old Dec 9, 2005 | 05:10 PM
Tim's Avatar
Tim
try karl at NMS For your map etc you wont be dissapointed.
Tim
link in sig
Old Dec 9, 2005 | 08:14 PM
DazC's Avatar
DazC
You should not gain power by a simple engine management swap. What you should gain is drivability and the potential for extra power.
Old Dec 9, 2005 | 10:56 PM
zippyobrien's Avatar
zippyobrien
youll also gain chatter and lots more tourque. also it will stop you from running lean at high revs. (mfi runs out of fuel at around 16psi fuel)
Old Dec 12, 2005 | 08:03 AM
Ezzy Danny's Avatar
Ezzy Danny
again cheers guys most appeciated!
Old Dec 12, 2005 | 10:19 PM
RST Ski's Avatar
RST Ski
thank you mr howell
ofab ecu? whats that? (original frst ecu?)
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
