How to cut......
Old Dec 5, 2005 | 07:45 PM
Default How to cut......
.....braided hose!!!!!
What is the best tool..as all i get is frayed edges so the fitting wont fit
PLEASE HELP its doin my head in
Old Dec 5, 2005 | 07:49 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Re: How to cut......
what diameter? big stuff... bind it with masking tape and put it in a vice, then hacksaw straight through it...
Old Dec 5, 2005 | 07:50 PM
Graceland's Avatar
Graceland
Team HOTHOT!
martoon beat me to it
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
you have pm
Old Dec 5, 2005 | 07:52 PM
Cowboi's Avatar
Cowboi
as said above, tape both sides of where your going to cut before you cut it.
try and get the tape as tight round the hose as possible, should cut alright then.
use a fine toothed hack saw blade if you ca as well so it dont grab at the metal.
if its still bad then turn the blade round in the hack saw so that it is actually cutting when your drawing the saw back towards you. that will help reduce the blade snagging the metal and bending it.
Old Dec 5, 2005 | 08:23 PM
Cheers everyone
Old Dec 5, 2005 | 08:40 PM
RichardPON's Avatar
RichardPON
Try not to put too much tape on, as it makes it harder to get the cutter fitting to start properly.
Just a couple of winds round is fine.
Old Dec 5, 2005 | 08:41 PM
Rick's Avatar
Rick
thin stuff - chisel
Old Dec 5, 2005 | 08:42 PM
rsnissan's Avatar
rsnissan
you can cut the frayed bits off with tin snips if you make a hash of it
Old Dec 5, 2005 | 08:43 PM
Ginge !'s Avatar
Ginge !
just finding my feet
id use one of them concave style cutters that you see advertise that cut pennys in 2
for large stuff i would use a grinder
Old Dec 5, 2005 | 08:46 PM
Rick's Avatar
Rick
for large stuff i would use a themic lance
Nothin like over doin it
Old Dec 5, 2005 | 08:55 PM
Eagle's Avatar
Eagle
Super Moderator
insulating tape ... and hacksaw
Old Dec 5, 2005 | 09:03 PM
MK5RST's Avatar
MK5RST
vice and one of those extra thin grinder blades
Old Dec 5, 2005 | 10:48 PM
Ginge !'s Avatar
Ginge !
hey if a jobs worth doing
cowboi is another one who would rather use a manual saw to cut tubing ect, when we was fitted a exhaust to my cabrio we needed to chop a few pipes and join em and hes got the most over stocked tool collection known to man, HE GRABS THE FUCKING SAW and starts to cut the pipe with it
i got the angle grinder and cuts the fucking thing like ya ment too
he excuse is its not a tidy or acutate way of cutting so he prefers the LONG way
Old Dec 6, 2005 | 06:37 AM
Cowboi's Avatar
Cowboi
i must admit ginge, u did cut the pipe. u cut everything else at the same time, but the pipe did get cut.
half the resaon was though i only had a grinding wheel on my grinder not a cut off wheel.
so it was never gonna make a good gob of it
Old Dec 6, 2005 | 07:01 AM
Ginge !'s Avatar
Ginge !
bollox you just like precision
i just like using grinders , i think im gonna cut the fucking bottom puly off with me grinder
Old Dec 6, 2005 | 10:26 PM
SS1's Avatar
SS1
