FAO experts!!!!MARTIN HADLAND!!
Old Dec 5, 2005 | 05:35 PM
Default FAO experts!!!!MARTIN HADLAND!!
...can you run a weber fuel pressure reg upside down its on a 4x4 rail so it bolts to the end and will fit properly upside down...you see i need to do this as the bonnet wont shut otherwise
I dont see a problem except the return is having to travel up then down!
Old Dec 5, 2005 | 05:38 PM
DaveEscos's Avatar
DaveEscos
why not remote fit it ?
Old Dec 5, 2005 | 05:42 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
i think martin hadland used to run one upside down phil
Old Dec 5, 2005 | 05:55 PM
i got a 4x4 rail which has had the fuel reg put on at a angle to fit the ecos
Old Dec 5, 2005 | 06:01 PM
Nige yes the original runs it at an angle...i have got a saff 4x4 rail with dash fittings on the intake end and on the fuel return as the reg is a Mountune item adjustable Grp A suspossed so dont want to change it!!
Old Dec 5, 2005 | 06:32 PM
ian sibbert's Avatar
ian sibbert
Phil,
You can run the reg anyway up u like.....
Old Dec 5, 2005 | 06:36 PM
Cheers mate
Just need an elbow -6 fitting and i will be fully aeroquipped up
DavidK
Sep 27, 2015 02:55 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
martysmartie
Sep 6, 2015 10:22 AM
Mark Mawson
Aug 31, 2015 07:09 PM
