90 Spec
depends if the 90 spec had a fuel computer, if it does u'd need to swap over the lil cubby hole bit (they never stick
), also u may be left with a hole if the 90 spec bits had a heated screen button
it will all phisically fit tho
just the options that make the odds
), also u may be left with a hole if the 90 spec bits had a heated screen buttonit will all phisically fit tho
never had the need to swap em between the styles mate so cant help there, some say they are some say they aint
worth a try i spose, they read same with either set fitted then ur away, just take them old 1's out and plug new uns in to check they are a go'er
Originally Posted by rs tommy
cool, the loom for the speedo the same?
Doesn't matter what set of clocks you have, it will know what's what - don't argue when I know I am right lol
Also, why are you mentioning th mk3??
We're talking mk4 here...of course the mk3 is different, we ALL know this
Well, how come on the 4 escort mk4's I have had it don't matter what instrument cluster you put in - it works!!
I know the backs are different, I am not saying they are not
You're being lame, I'm purely telling the chap asking it WILL work no worries
ok, so i am the only one that had probs when i swapped the 86-87 instrument to a 88-90? I had to put the heat gauge where the petrol gauge is. Just look at the white dials you can buy, some have the heat gauge to the left and some to the right, now that should be a big mysterie then.............
Not really, the design is different indeed
When I had the fuel gauge on the right, I had a problem because I needed it on the left so I could put a gauge in where the wter temp was (electronic one)
I got some of the newer spec dials and plugged in to see if I could use them, it worked fine so just used them
I did not change any of the wiring at all, neither did I have to swap anything over
Don't mean to be rude, but you really are making yourself look like a right cock, I am right, I KNOW I am right, so just don't argue about it
You have some mk3 parts, that's why it's so fvvcked up mate
