Pectel Monitor - Fault Code!??
Old Dec 2, 2005 | 01:07 AM
Kelv's Avatar
Kelv
Almost there!
Default Pectel Monitor - Fault Code!??
Picked my car up late this evening from having the extra fuel pumps ad swirl pots fitted in car and being setup correctly.
but as i pulled into my road the car started to misfire quite abdly, being that i was just touching the red i guessed it may have been fuel pressure!
anyway, i limped to the garage and filled up, and as i pulled away it was the same, so i set my pectel monitor to the error code setting and it was showing 2 codes...
Error 1 - Crank/Cam Sensor US1 & Error 2 - Crank/Cam Sensor US3
Would anyone know exactly what these codes are? as ive spent a while in the workshop removing and cleaning up the crank sensor for no difference, even tried another crank sensor and it apeared to have cleared it, but half way home the car started to pop and bang everytime at exactly 5500rpm and the 2 Error codes have reappeared again
Anyone got a cure atall, or had this problem?? - and over come it?
Kelvin
Old Dec 2, 2005 | 08:25 AM
wes's Avatar
wes
Probably the sensor inside the dizzy, common fault! Fit a new one, job done
Old Dec 2, 2005 | 08:36 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
What he said. If it comes up with this code, it means the sensor that it mentions has failed.
tankybaby66
Feb 6, 2016 02:24 PM
jay030787
Sep 25, 2015 01:38 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Roscopeco
Sep 14, 2015 05:32 PM
Si B
Sep 12, 2015 06:49 AM
