S.E.C'S Monitor water injection
is the sec monitor water injection take off any good?? how does it work?? worth connecting up?? or is mapable water injection worth getting??
cheers
cheers
it will be as good as the secs monitor is..
mines been as good as gold, touch wood!
It will controll your signal to the WI pump via the set boost pressure AND/OR the ACT temp
so should work pretty well!
run a lead from the WI feed to a relay to the pump
no probs mate.. hit both buttons together to get in to the menu, then you can set the WI parameters
ta most appreciated
not sure... my WI map is set in my ECU
i'd guess at around 40 degs inlet charge?
Mike Gaylord will know for sure.... he is a floppy haired c-unt.. but a helpfull one all the same!
this abuse this poor bloke gets on here ! ! ! funny tho
sorry Mike
.Dene,
The strategy found to work best is if the boost is above 7psi and the ACTs exceed 42°C.
Tosser
Dene,
.Dene,
Lovely job Mike thanks very much for your input oh and dave cheers
most appreciated
Mark RS
Oct 12, 2015 06:01 AM
