engine identification.. help (difference in core plug sizes)
Old Dec 1, 2005 | 08:22 AM
stu21t's Avatar
stu21t
Default engine identification.. help (difference in core plug sizes)
if i got an engine number off a 205 block engine could some1 here tell me if its a thick or thin walled block?
ive been told that there were 2 different 205 blocks, a thin walled one that can take about 350 bhp and a thick walled one good for 500+
is this true?
and if it is and i put up the engine number could some1 here tell me what it is?
cheers
Old Dec 1, 2005 | 08:24 AM
GARETH T's Avatar
GARETH T
no need for engine numbers,, what size are the core plugs
Old Dec 1, 2005 | 08:40 AM
stu21t's Avatar
stu21t
pass
what sizes mean what?
lol
i will go and measure them but what sizes am i looking for?
cheers
Old Dec 1, 2005 | 08:44 AM
GARETH T's Avatar
GARETH T
i cant remember off the top of my head,, i just know the better block has smaller plugs
Old Dec 1, 2005 | 08:46 AM
stu21t's Avatar
stu21t
ok but i dunno what size the bigger ones are. lmao
i could measure them and still dunno what it means. lol
is there anywhere else that says about it?
Old Dec 1, 2005 | 09:49 AM
stu21t's Avatar
stu21t
any1?
Old Dec 1, 2005 | 11:21 AM
ronf42's Avatar
ronf42
you could look here on this site
http://www.siipicossu.com/manuaaleja/manuaalit.htm
if not here , i am sure this site will be of some use anyway for the manuals.
Old Dec 1, 2005 | 05:05 PM
stu21t's Avatar
stu21t
any1?
Old Dec 1, 2005 | 05:13 PM
Tony Ryan's Avatar
Tony Ryan
The std 205 blocks are coded YBB , the RS 500 Block is identical apart from the crank webs beefed up , the core plugs are smaller and weighs a lot more , thats coded YBD if that helps
Old Dec 1, 2005 | 05:14 PM
stu21t's Avatar
stu21t
where do i finds the ybb or ybo codes?
cheers
Old Dec 1, 2005 | 05:16 PM
Tony Ryan's Avatar
Tony Ryan
YBD not o , lol . the engine numbers are above the water pump on most engines , nicked ones are obvious from the angle grinder marks at this point !
Old Dec 1, 2005 | 05:18 PM
abdr500's Avatar
abdr500
the small core plug block is the rs 500 block .the core plug is about the size of 10 pence and as for the other 205 block its almost the size of a jaff cake
Old Dec 1, 2005 | 05:25 PM
stu21t's Avatar
stu21t
lol right off to check.
Old Dec 1, 2005 | 05:33 PM
stu21t's Avatar
stu21t
think its a std block
couldnt find the engine number or angle grinder marks. lol
i did see a large number atthe bottom of the exhaust manifold side that ends in BB
and the core plugs look larger than a 10p
j.hammond1
30
Oct 31, 2021 05:28 PM
muz
Aug 16, 2015 12:57 PM
Roosie
Aug 15, 2015 08:09 PM
Zoggon
Aug 10, 2015 10:39 AM
