Temp Guage
Old Nov 28, 2005 | 03:44 PM
RST Ski's Avatar
RST Ski
Default Temp Guage
wots evry1s temp guage read at when normal op temp? my never gets above quarter of the way, got hot air inside the car now with a new stat
Old Nov 28, 2005 | 04:50 PM
wish mine did. its always in the red
Old Nov 28, 2005 | 04:52 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Ford temp gauges are crap, they aren't calibrated and are pretty meaningless most of the time. This time of year just from normal driving on main roads I see 80c, so the stat isn't even opening. Foot down giving it plenty of beans I see 95c ish. Even that isn't right though because my manifold heats up my water temp sender.
So probably only seeing about 90 ish
Old Nov 28, 2005 | 05:13 PM
whats a good temp gauge to get?. Also silly question where does this it fit to/in? the sender?
Old Nov 28, 2005 | 05:17 PM
Tony Turbo's Avatar
Tony Turbo
Depends on your budget, obviously a £100 gauge is better than a £10 one.....
My Defi sender fitted into the original one's place at the front of the head. I need to either take the loom apart and move it to the back of the head, or make a heat shield for it
I'm not that bothered because I know how my car is and if I plan on abusing it all day I plug the laptop in and check on it properly, along with other things.
Old Nov 28, 2005 | 06:21 PM
RST Ski's Avatar
RST Ski
think il get a differnent temp guage
Old Nov 29, 2005 | 12:13 AM
can u recommend a gauge say for about £100?
Old Nov 29, 2005 | 08:34 AM
zippyobrien's Avatar
zippyobrien
at what temperature does it become dangerouse.
what is the limit?
just wonderin as im going to get a water temp gauge and i want to know at what temp i should get worried???? lol
cheeRS
Old Nov 30, 2005 | 08:04 PM
Tony Turbo's Avatar
Tony Turbo
I only have expirence of my Defi, sorry...
Old Nov 30, 2005 | 08:05 PM
Tony Turbo's Avatar
Tony Turbo
108- 110 at the most really. But you normally want to see around 100 tops.
Old Nov 30, 2005 | 10:42 PM
AJC's Avatar
AJC
mine is at half way, goes up to 3/4 and fan kicks in,
then back down to half
Mark RS
Oct 12, 2015 06:01 AM
15
Oct 7, 2015 03:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Ben26
Sep 3, 2015 07:55 PM
