another rolling road debate
just had my rs on the rollers and it made 131bhp and 146 lbft torque at 10psi which to me is not good for a fully rebuilt engine?
the plugs are coked tho so would that affect it?
any opinions?
any opinions?
it is standard napart from zorst and filter. just a normal mechanic built the engine
i didnt put coked plugs in they were freshens but it was overfuellin a lot. need to change them now i think
i havent seen him yet im at work he just toldme over the phone it was set up too it made 120 on the first run. he ran it at 15 and 20 too but the boost cut off due to no chip.
jimmy it wants setting up right mate
take it to m.s.d and let kenny give it the once over, years ago mine made 181@fly with 179lb torque with 15 psi and just a boost chip and the fueling sorted , and uprated actuater, otherwise it was standard
andy
take it to m.s.d and let kenny give it the once over, years ago mine made 181@fly with 179lb torque with 15 psi and just a boost chip and the fueling sorted , and uprated actuater, otherwise it was standardandy
The alarm bells are ringing. I have a horrible feeling we have a garage that just turns the boost without anything else. POwer figure for even those minimal mods should be more than that
i know this is my worry. i think its more my car than him cos he knows what hes doin and has a good rep. maybe a whole new bottom end is needed. i dont think it has been built well i only had it done cos it was cheap and its a temp thing. im uprating it all soon
first few things that will make it run better
1. take dump off if leaking
2. dissconnect bleed valve
3. get a new actuater from m.s.d
4. buy a boost gauge
5. set new actuater up to 7/9 psi
6. get fueling sorted
all above are just basic stuff that any good tunner will now
andy
andy
