Abs
Old Nov 28, 2005 | 11:00 AM
RST Ski's Avatar
RST Ski
Default Abs
Does every1 removed there abs?
Old Nov 28, 2005 | 11:03 AM
SamERST's Avatar
SamERST
Not out of choice lol my belt snapped i like it to be honest
Old Nov 28, 2005 | 11:07 AM
addiction's Avatar
addiction
having snapped or removed belts is not the same as having the abs removed properly!!!!!
Old Nov 28, 2005 | 02:00 PM
Oranoco's Avatar
Oranoco
I binned my ABS as it's shockingly bad. Best thing I did.
As per addiction, removing the belts only is not removing the ABS.
Old Nov 28, 2005 | 02:02 PM
turbo.jon's Avatar
turbo.jon
Binned all mine its got all bits off a 3i i broke up it is a lot better now
Old Nov 28, 2005 | 02:32 PM
andre_k's Avatar
andre_k
i quite like mine, my belt snapped, it ws shit, then a new belt was put on and its alot better
Old Nov 28, 2005 | 02:51 PM
Oranoco's Avatar
Oranoco
Once you have binned the ABS properly you will never look back. The feel is so much better than with it on. Saying that though as our Fiesta is used on the road a fair bit it won't be being removed.
Old Nov 28, 2005 | 04:56 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Yeah, one od the best things I did was to ditch that crap.
Old Nov 28, 2005 | 05:11 PM
i still got ABS on there but not running any belts. i will be removing all this shit soon though. bastard bits are a pain in the arse when doing a gearbox
Old Nov 28, 2005 | 05:12 PM
RST Ski's Avatar
RST Ski
easy to remove? the abs i mean?
Old Nov 28, 2005 | 07:18 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
i wanna do it too but cant be arsed till sum1 puts the lot together and sells it at a nice price,, have a regulator handy but bahhhh
jon did you get your pipes made up in the end?
does it work right or the rear like to lock up?
its all hanging ogff my red 1 so it cant go back on now ist all mangled
Old Nov 28, 2005 | 07:45 PM
AKRS1's Avatar
AKRS1
As i have witnessed so many times a real pain in the butt
Old Nov 28, 2005 | 09:19 PM
Taylor's Avatar
Taylor
What is required to get rid of th abs fully?
Old Nov 28, 2005 | 09:53 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
a weekend off hell under your motor,covering yoursell in shite,pullin bits off,and reconecting the new stuff on i guess,
mind you ,just putting new steering rack bushes on does the same to you,ficking nightmare
Old Nov 28, 2005 | 11:22 PM
Taylor's Avatar
Taylor
akito-man I know it will probably be a pain i the arse,expected that!
Anyone know what it takes though?
Old Nov 29, 2005 | 05:23 PM
1.9 xr2 on 40's
st170 breaking
you basically, take off you abs bellows, swap over to the non abs master cylinder and make up some brake pipes to join up to the others at the inner wings, there shud be the regulator whatsit to make sure the rears get less pressure too to save you gettin too much braking to rear and locking up or swapping ends
Old Nov 29, 2005 | 05:29 PM
Taylor's Avatar
Taylor
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
