I need to upgrade my brakes, suggestions/advise please!
Old Nov 27, 2005 | 08:39 PM
GraphiteGray's Avatar
GraphiteGray
Default I need to upgrade my brakes, suggestions/advise please!
I need to upgrade the brakes on my RS, im going for the XR4i rear disc conversion but need some advice on the fronts, currently i have the S1 setup with grooved discs and mintex pads, im undecided whether to fit s2 calipers (do these fit straight on?) or use the cossie setup
Whats the best option? how hard are they to fit? and whats the difference between 2WD cossie calipers and 4WD calipers and would both types be okay to fit oh and will i have to change the master cylinder?
Anyone?
Old Nov 27, 2005 | 08:44 PM
320 bhp's Avatar
320 bhp
I HAVE 4X4 COSWORTH CALIPERS AND 2WD DISCS ON MY S2 EASY TO FIT ONLY NEED A 1MM WASHER BETWEEN THE HUB AND THE CALIPER STOPS EXCELLENT I ALSO HAVE XR4I REAR DISC SET UP,OTHER OPTION IS 2WD DISCS AND S2 CALIPERS WITH A BRACKET SO THE CALIPER SITS HIGHER
Old Nov 27, 2005 | 09:06 PM
GraphiteGray
2WD discs and S2 calipers sound good where do i get these brackets from?
Old Nov 27, 2005 | 09:09 PM
320 bhp's Avatar
320 bhp
MITE BE A SET ON EBAY HAVE SEEN THEM ADVERTISED SOMEWERE TRY BURTON POWER OR SOMEWERE LIKE THAT
Old Nov 27, 2005 | 10:22 PM
NUTS RuS's Avatar
NUTS RuS
Brand new 288mm rotors with new lightweight alloy 4 pot calipers any use ? Will fit under 15" wheels no problem.
Ł630
Old Nov 28, 2005 | 03:01 PM
zippyobrien's Avatar
zippyobrien
mad for it (www.mad-for-it.com) sell the brackets (in stainlesteel) for the front to use 2wd cossie discs and seriers two calipers. they also sell the requires braket for the rear disc conversion. there Ł25 for the front and Ł25 for the rear.
Old Nov 28, 2005 | 03:07 PM
Oranoco's Avatar
Oranoco
S2 RST rear drums and Cossie callipers and 2wd discs up front will be ample stopping power
Old Nov 28, 2005 | 07:19 PM
GraphiteGray
Ł630
THey sound top notch mate but sadly theyre out my price range
Gonna go for the Cossie discs and S2 calipers methinks will my master cylinder be good enough or should i fit an S2 one?
Old Nov 28, 2005 | 07:58 PM
andysrs's Avatar
andysrs
Default hi spec
graphite i got 288 up front on four pots and 260 on the back nearly puts you threw the screen even with a little dab
Old Nov 28, 2005 | 09:47 PM
GraphiteGray
I agree they look the dogs but the wallet is empty
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
