lead order on s2
can any one tell me the correct order the plug leads go on on a 86/7 s2 rst
no1 on the dizzy being the hole closeist the the front panel 2 being top rear 3 being bottom frot and 4 being bottom rear hole
cheers
cheers
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
Firing order is 1-3-4-2. Set no 1 piston to TDC, where ever the rotor arm points to is for HT lead number one, work around the distributor anti clockwise using the mentioned firing order.
The Youth.
Sep 30, 2015 09:59 PM
