My new suspention geometry - comments?
Old Nov 27, 2005 | 05:34 PM
Azrael's Avatar
Azrael
Default My new suspention geometry - comments?
So, car's back on road and I got it setup. It's 170mm/180 front/rear ride height.
Now geometry was setup with winter in mind, so 195/55R15 winter tires!!
It goes as follows:
Front(L/R):
camber -2°21'/-1°50'
caster 3°37'/3°09'
toe 0°04'/0°03'
wheelbase - 2548mm/2547mm
Rear (L/R):
camber -2°10'/-2°27'
toe -0°09'/0°13'
It's set up a little bit on front to give it some stability under braking and make it a little less nervous in slippery conditions. Front camber was set-up with much narower tire and little grip in mind, that's why so little of it.
The thing I am most concerned about is wheel base difference of 1mm and rear toe which is little out of tolerance. What do you think? Schould I be concerned about it? It drives very well (for a winter wheel of course) but pulls just a little bit to the right :-( Not that you can't let the wheel go for a while but you have to keep correcting it once in a while to the left.
The best solution would be adjustable beam but it will be hard and costly to ship that to Poland so I still wonder when I can get it. Schould I be trying to get it ASAP?
Old Nov 27, 2005 | 08:08 PM
NUTS RuS's Avatar
NUTS RuS
Ignore the wheelbase - production tolerance was more than that I'd guess.
Is it pulling to the right due to the camber in the road - is that why you have slightly less on the front right ?
Ignore the book now you have the basic setting and use the ass dyno instead
Old Nov 27, 2005 | 08:13 PM
Rick's Avatar
Rick
Could u get a beam in a mk4 escort? As i could drive it over for u when we goto the ring
Old Nov 27, 2005 | 08:15 PM
Azrael's Avatar
Azrael
Oh, OK. Probably true.
I think it's pulling to the right due to suspention geometry - maybe the rear toe?
It's not big thing but little anoying. Of course it may be that all roads around me are bent to the right but I don't belive they are so much. Other cars don't do that but none is on so hard suspention- I belive that influences it much.
Maybe it's due to the fact it's not cornerweighted?
:-D Ass dyno in corners tells me that there is no grip overall "wrrr,pssst,wwrr,psst,wrr,wrr,psssst,wrr,psstt " and sideways in every corner if I try to aply some throttle But my winter wheels are a bit funny looking when driving on tarmac.
Old Nov 27, 2005 | 08:17 PM
Azrael's Avatar
Azrael
Dunno.. and I don't know if I could fit it into the car on the way back :-/
It's pretty cumbersome. There is still some time - we can think about it.
Old Dec 19, 2005 | 11:15 AM
Azrael's Avatar
Azrael
Now....
Done about 1500 km's, still pulling to the side but apart from that handling well I think. Still on snow I have to opposite lock to the left when accelerating hard, may this be due to the rear toe in-out slightly out of tolerances? Or should I just have it reset once more because new suspention could kind "settle"?
dojj
111
Jun 10, 2018 09:09 PM
IainRS1700T
Sep 25, 2015 06:44 AM
landaqmabba
Sep 15, 2015 07:16 PM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
