whats best head gaskett 4 stage3 cosworth
Old Nov 27, 2005 | 10:16 AM
s1 2oobhp's Avatar
s1 2oobhp
Default whats best head gaskett 4 stage3 cosworth
looking 4 a good head gaskett 4 my sierra cosworth its running stage 3 or any1 that can fit in essex cheers
Old Nov 27, 2005 | 10:17 AM
TIFF's Avatar
TIFF
Chasing Radders
Mountune 4 Layer WRC Headgasket
Old Nov 27, 2005 | 10:22 AM
Ginge !'s Avatar
Ginge !
just finding my feet
as tiff says
but if you mean what will be sufficient for a stage 3 cossie then the answer is a genuine group A head gasket
the montune needs a totally flat head and block deck ( means skimming em in most cases) the group A and that fussy as such and aint 400 quid
the montune is ideally for greys and over, the commetic is ok too no matter what a few people may claim as loads of others AINT had a problem
Old Nov 27, 2005 | 10:39 AM
SapphyMike's Avatar
SapphyMike
the new cometic should be fine, but as with any metal gasket, the head and block faces need to be 100% Perfect and flat, as they dont cover some of the imperfections that a fibirous gasket can.
Old Nov 27, 2005 | 11:11 AM
s1 2oobhp's Avatar
s1 2oobhp
will the engine need 2 come out 2 have the block skimmed or 2 make it flat or best just 2 go 4 the fibirous group A gaskett thanks 4 the help lads
Old Nov 27, 2005 | 11:16 AM
Ginge !'s Avatar
Ginge !
stage 3 i would go group A
well actually i am
Old Nov 27, 2005 | 12:01 PM
JamesH's Avatar
JamesH
Group A late EsCos one
Old Nov 27, 2005 | 12:24 PM
Has your gasket blown, or are you just being cautious and want to fit a new one?
IF yours has blown, then skim the head, when you fit a new one.
Unless you know the block is flat, i wouldnt fit a metal one personally, they just arent as forgiving.
To flatten the block means taking the engine out and then stripping the engine down, as when its skimmed swarf will go into the oil and waterways.
Old Nov 27, 2005 | 12:37 PM
Damo V's Avatar
Damo V
WRC 4 Layer for me, oh by the way Ginge I only run Light Blues
But that was fitted to new bl;ock head etc
IMO just fit a fibre one and keep boost sensible (I had a cometic fail)
Old Nov 27, 2005 | 01:10 PM
Ginge !'s Avatar
Ginge !
Damo you also are a perfectionist
if hes not gonna skimm the block then my advise is correct
Old Nov 27, 2005 | 01:15 PM
Damo V's Avatar
Damo V
As I said, "IMO Just fit a fibre one"
Old Nov 27, 2005 | 01:19 PM
Ginge !'s Avatar
Ginge !
you could have added "i would take ginges wise and technical help and fit a fibre one
Old Nov 27, 2005 | 01:21 PM
Damo V's Avatar
Damo V
Trouble with that is he may think I mean "In general" as opposed to specifically regarding this thread....
Old Nov 27, 2005 | 01:23 PM
Ginge !'s Avatar
Ginge !
thats what i hope
Old Nov 27, 2005 | 04:40 PM
s1 2oobhp's Avatar
s1 2oobhp
head gaskett has failed found the oils got like milk in it im going groupA as dont want 2 take the engine out 2 get the block skimmed
thanks about the cometic head gaskett info
any 1 no the part number 4 the ford groupA gaskett as the escort big turbo will b the same? cheers lads
Old Nov 27, 2005 | 04:42 PM
Damo V's Avatar
Damo V
Its the small turbo ECos one you need..
Old Nov 27, 2005 | 04:48 PM
Mechanic_Wedgie's Avatar
Mechanic_Wedgie
Is that the Escos with the "new" engine??
Old Nov 27, 2005 | 04:50 PM
Ginge !'s Avatar
Ginge !
yes,the new engine and shite turbo that only DOO would like
Old Nov 27, 2005 | 06:00 PM
Damo V's Avatar
Damo V
YBP Engine, 1995 onwards
Old Nov 28, 2005 | 05:52 PM
Mechanic_Wedgie
Is this engine called a EEICV or something like that, engine??
Old Nov 28, 2005 | 05:58 PM
Billabong's Avatar
Billabong
EECIV
Old Nov 28, 2005 | 06:42 PM
Mechanic_Wedgie
Originally Posted by Billabong
EECIV
arrghhh almost
SmudgerByName
52
Jul 28, 2016 06:14 PM
turbotrev
Aug 22, 2015 11:41 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
