Cossie problem???????
Old Nov 26, 2005 | 09:58 PM
Alps Pacino's Avatar
Alps Pacino
Default Cossie problem???????
My 2wd has had a miss at the top end of the revs for a while now, i was told it was probably the cps or phase sensor. I changed the cps and still no joy.
But tonight was racing a turbo nova changing gear early etc so it wasnt missing, anyway came to some traffic so chilled out, once the car moved went to send her away again but it just cut out and died and missed like fook when trying to even give it very light throttle. I then pulled over let it tick over for a while and then set off home car was fine driving as normal for a few miles then it started missing but only after it hit boost, drives perfect off boost.
I thought i had possibly melted a plug but just whipped them out and there all fine.
ANY IDEAS WOULD BE MUCHO APPRECIATED
Old Nov 26, 2005 | 10:02 PM
Ginge !'s Avatar
Ginge !
just finding my feet
aint got a clue what it is but i bet it costs ya
Ginge !'s Avatar
Ginge !
you have changed the rotor arm and dizzy cap yeah
Old Nov 26, 2005 | 10:03 PM
gazcos's Avatar
gazcos
I had a similar thing in my 3 door. I bought a new phase sensor but when i went to set the gap up on it i found the spindle in the dizzy was so worn that i couldn,t set the gap at all.Must have spun round ok at low revs then go all wonky when giving it beans
Old Nov 26, 2005 | 10:08 PM
Alps Pacino
I have changed the rotor arm dizzy cap leads about 3k ago plugsw were changed less than 1k ago. Cossies are fooking wank roll on the purchase of the integra
Old Nov 26, 2005 | 10:17 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
as long : as i get me engine bud banana:, and our lass is eyein up ur bandit !!!!
feckin women eh only happy when theres sumfin vibrating between there legs lol
have a sleep cossie mite be better in the morning ,
bri
Old Nov 26, 2005 | 10:27 PM
Alps Pacino
beefy-rst-2
It best be better in the morning or it will be getting burnt out to provide heat for me while i work on the nova
Old Nov 26, 2005 | 10:47 PM
-beefy-'s Avatar
-beefy-
well get the management off it for me first will ya mate !!!!
txt u tomorow , going to have a go on the missus
peace
bri
Old Nov 26, 2005 | 11:08 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
racing a turbo nova?
a 400bhp cossie will struggle with a turbo nova!!!!
make sure your fuel pump is giving enough juice at high revs.
Also check your phase sensor wires arent stickin out inside the dizzy!!!
any more problems/wrong replys please let me know!
Sean.
Old Nov 26, 2005 | 11:19 PM
Alps Pacino
Cossie Sean
So could be the phase sensor then, na turbo novas/corsas aint that much cop tbh, a mates s2 used to keep up with nova turbo's.
I convincinly pulled away from this onw tonight short shifting at 5kish.
O and i aint go the ford blinkers on cause i own a xe nova
Old Nov 26, 2005 | 11:29 PM
Cossie Sean
i run a 400 or so bhp cossie and i seriousley respect nova/cosra turbo`s!!!
my saff currently runs :
knife-edge crank/worked rods
headwork/cams/pulleys
T35
greys
very wild ANTI-LAG
if i race a nova/corsa turbo and win, i think myself lucky.
respect to these fookin lunatic wagons
Old Nov 26, 2005 | 11:43 PM
Alps Pacino
It would have to be some seriouse nova to keep with a 400+ bhp cossie imo
Old Nov 27, 2005 | 12:09 AM
Cossie Sean
just think power/weight ratio.......................
Old Nov 27, 2005 | 12:13 AM
Alps Pacino
But ppower to weight ratio looses its affect at high speeds its sheer power that has the advantage once up to speed. I bet if you worked it out a 400bhp saph would have a better power/weight ratio than a 250bhp nova turbo
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Thanasis
Sep 7, 2015 07:33 PM
routemaster
Sep 7, 2015 05:27 PM
