push button starter wiring? help!!!!!!!
Old Nov 26, 2005 | 08:06 PM
zippyobrien's Avatar
zippyobrien
Default push button starter wiring? help!!!!!!!
going to fit a push button starter tomorrow.
do i just get the starter motor wire up by the steering colum (any one know what colour it is ?) cut it, join it to my push botton, then run the other wire from the starter button to an earth?
please help lads and lases
thanks in advance zippyobrien
Old Nov 26, 2005 | 11:25 PM
NUTS RuS's Avatar
NUTS RuS
No
Find the wire that operates the starter solonoid, cut it, extend one side to the button, then from the button re-join it back to the loom.
The button then makes the circuit when pressed.
Old Nov 27, 2005 | 11:14 AM
Glen's Avatar
Glen
Starter wire is black with blue stripe. (on older fords such as cossie's FRST's and ERST's etc, you don't say what car it is ??)
You need to be sure the button you are using can handle the solenoids current draw first !! if not you need to relay your button mate.
You need a normal 4/5 pin automotive relay.
Cut the black blue (starter wire) and connect one side to pin 30 and the other to pin 87 on ya relay.
On your switch connect one terminal to +12V (red wire in coloum, you should fuse your supply too), then the other switch terminal to pin 85 on your relay. Now just need a ground on pin 86 and ya done, if you've used a 5 pin relay just leave pin 87a as it's not needed.
Old Nov 27, 2005 | 11:38 AM
NUTS RuS's Avatar
NUTS RuS
Thanks Glen
I couldn't be bothered doing the full version, but didn't want a 'help it dosn't work' post today
Old Nov 27, 2005 | 01:55 PM
zippyobrien
if i just cut the wire, put it to my button then back to the loom, ill have to hold the key as if im starting the car then push the button.
i dont want to hold the key whilst pressing the button.
i got the switch of ebay, its a billet piece of alloy with a aircraft style switch and a big black button fot the starter. i was gunna wire it so you have to flick the big air craft switch then push the black button. the switches look pretty beefy
does the wire that goes to the actuator go to ground to make the starter motor spin??????
Old Nov 27, 2005 | 01:57 PM
zippyobrien
oh yeah
thanks very much for the advice 'nut RuS' and 'glen'
its much appreciated
Old Nov 27, 2005 | 08:08 PM
Glen's Avatar
Glen
Good point mate !!!!!!!!!!
Cut the wire off of the barrel connect it to pin 87 on the relay. And connect pin 30 to +12v must be a good supply, would suggest defo the red wire upto the barrel !!!!!!!!
Good luck !
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Mark RS
Oct 12, 2015 06:01 AM
