Light switch
Old Nov 26, 2005 | 06:27 PM
AKRS1's Avatar
AKRS1
Default Light switch
Hi i have a s2 and i have a small problem when you switch the headlight switch to sidelights its fine but when you switch it on to the main lights the lights turn off but after playing around with it they turn on have tried a new column stalk but still the same and does it mostly when you get in the car in the morning could it be a possible relay problem
Old Nov 26, 2005 | 06:30 PM
withamxr's Avatar
withamxr
ive got the same problem
sometimes they wont come on for 10 mins
Old Nov 27, 2005 | 02:22 PM
Jo's Avatar
Jo
I had the same problem too. It was a relay problem on my car. Try to wiggle the relay if they don't come on and see what happens.
Old Nov 27, 2005 | 02:30 PM
bazpro's Avatar
bazpro
had same problem when i had my rst it turned out to b a loose wire under the fuse box was shorting them out.
Old Nov 28, 2005 | 02:44 PM
AKRS1's Avatar
AKRS1
thanks for advice people will have a look at the fuse box
Old Nov 28, 2005 | 02:49 PM
Oranoco's Avatar
Oranoco
Had this on mine and it was the contact for the relays in the fusebox. I just disconected the battery and used a mini screwdriver to bend the terminals to give a better contact.
Hasn't given me another problem in about 5 years
IainRS1700T
Sep 25, 2015 06:44 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
The Enigma
Sep 12, 2015 10:12 PM
fuzzy
Sep 4, 2015 10:11 PM
