can you get aftermarket pulleys on front of a cossie engine
Old Nov 26, 2005 | 06:02 PM
stu21t's Avatar
stu21t
Default can you get aftermarket pulleys on front of a cossie engine
i wanna change the pulleys on the front of my engine.
the bottom crank pulley only needs 1 belt connecting, i dont have power steering and only want 1 belt for the alternator and water pump.
can you get pulleys that are lighter and are made for only 1 belt?
and can i change the pulley on the front of the alt and wp?
Old Nov 26, 2005 | 06:39 PM
RS2000CUSTOM's Avatar
RS2000CUSTOM
I am building a Cozzy bottom end for my 8v Pinto
These are the pulleys I will be using
Got them from Vulcan Engines
Old Nov 26, 2005 | 07:03 PM
stu21t's Avatar
stu21t
cheers m8
got any contact details for em?
Old Nov 26, 2005 | 09:24 PM
stu21t's Avatar
stu21t
any1 else?
Old Nov 26, 2005 | 09:34 PM
RS2000CUSTOM
Vulcan Engineering - 02085 189136
www.vulcanengines.com
Whilst Pinto pulley kit will fit it does not have the ignition trigger sensor as per the Cozzy bottom pulley
Old Nov 27, 2005 | 10:02 AM
PAUL S's Avatar
PAUL S
You can get alloy ones with the trigger - try mountune
or people just slice off the auxilairy belt part from the front of a standard pulley as the triggers are closest to the engine - ideally needs balancing once done though
manuel boeckx
13
Oct 3, 2015 02:29 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
MARKYMARKONE
Aug 2, 2015 09:33 PM
