#2wd rebuilt engine £2200*
Old Nov 26, 2005 | 10:23 AM
Tabz @ S.M.Auto's's Avatar
Tabz @ S.M.Auto's
Default #2wd rebuilt engine £2200*
Only covered aprrox 3-4k miles
Can contact me direct on 07779 790 311, please no timewasters
rebuilt 2wd head,
32k mile cams used, new cam seals fresh line bore,
new tappets, new bronze guides, new oil seals,
decoked, pressure tested slight skim, valves cut back and reseated.
new exhaust manifold and inlet manifold studs
inlet manifold polished and refitted with cometic gasket.
205 block rebuilt using new mahle 0.5 oversize pistons,
new rings and pins, new water pump,
conrods used from a 32k mile engine,
new upper/lower bearings, new main bearings,
crank lightened and balanced, new high pressure oil pump,
big wing gaitored sump, new core plugs,
flywheel skimmed also lightened and balanced,
new ap 6 paddle clutch ( only covered 700 miles ).
cometics thicker multi layer head gasket. and all cometics gaskets used elsewhere, new servicable parts, i.e dizzy, rotor, pp8 plugs etc
brand new sensors all round, every one of them is new. New fuel regulator.
engine has only covered approx 3k miles and is sweet as can be.
EXTRAS: running stage 3 conversion, shall include L6 ecu, stage 3 chip, 3 bar map sensor, 803 green injectors, 909 leads.
no turbo or turbo manifold. Alternator, p/s pump etc still bolted on, also starter motor ( both starter and alternator are fully rconditioned )
Old Dec 19, 2005 | 12:08 PM
Tabz @ S.M.Auto's
upski.
Old Dec 19, 2005 | 01:16 PM
croppy's Avatar
croppy
bargin can't belive u ain't sold it yet m8
Old Feb 11, 2006 | 10:12 PM
Tabz @ S.M.Auto's
bttt
Old Mar 2, 2006 | 09:33 AM
Tabz @ S.M.Auto's
Price reduced for the las time now only £2600
Old Mar 2, 2006 | 02:31 PM
tregmatt's Avatar
tregmatt
should sell at that price
Old Mar 2, 2006 | 04:26 PM
Tabz @ S.M.Auto's
Seems like nobody needs a good engine at the moment
Old Mar 9, 2006 | 07:47 PM
Tabz @ S.M.Auto's
bttt
Old Mar 11, 2006 | 10:59 PM
Tabz @ S.M.Auto's
T3/4 turbo now available.
Old Mar 12, 2006 | 10:26 AM
Tabz @ S.M.Auto's
you have pm
cossiedean84
37
Sep 2, 2015 10:19 PM
mint_s2
Sep 2, 2015 08:58 AM
Tim Wharton
Aug 30, 2015 05:46 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
