silly questions
Old Nov 25, 2005 | 10:24 AM
JayRS2000's Avatar
JayRS2000
Default silly questions
seeing as im new to the rsturbo world please help me lol
a few silly questions but i dont av a clue and when ppl talk bout it im a bit lost
cheers jay
psi stands for -? bars off boost -? stages of boost-?
Old Nov 25, 2005 | 10:41 AM
T28 RST's Avatar
T28 RST
Ok then
1 bar of boost is 14.7psi of boost
Old Nov 25, 2005 | 10:45 AM
JayRS2000's Avatar
JayRS2000
cheers dude so im running over a bar
Old Nov 25, 2005 | 10:47 AM
T28 RST's Avatar
T28 RST
Ok then
The easy way i do it is
0.2 of a bar is about 3psi(its just under)
Old Nov 25, 2005 | 03:04 PM
JimmyBoy's Avatar
JimmyBoy
Easy way is just type it into google mate.
"1 bar in psi"
OR
"20 psi in bar"
As T28 say, 1 bar = 14.7 psi
psi stands for Pound per Square Inch (sometimes simply referred to as pounds, ie "Im running 20 pounds of boost"), this is simply a measurement of how much pressure is being produced by the turbo going back into the engine. The more you use the faster your car will be, but use too much and you will kill your engine if it hasnt been built for use with high boost, this is because hight boost can put alot of stress on the internals of your engine, and uprated parts need to be used to take full advantage of it.
Bar is just a different measuring method of psi
Stages of boost is usually referred to as Hi or Low boost. People will have a switch inside to flip from low boost (say 7psi) to hi boost (say 20 psi), this way they can drive normally on low boost, and when they wanna go a bit wild or chase after ferarri's they can flick the switch to "hi" and off they go!
Hope that helps a bit.
Old Nov 25, 2005 | 03:54 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
1 bar = 14.5037738 pounds per square inch
Old Nov 25, 2005 | 05:02 PM
DazC's Avatar
DazC
Don't be so pedantic you penis.
1 atmosphere is 14.7 psi!
Rod-Tarry
75
Oct 13, 2015 04:44 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
