T4 turbo whats stronger
Old Nov 24, 2005 | 08:55 PM
abdr500's Avatar
abdr500
Default T4 turbo whats stronger
rs 500 t4 turbo hybrid spec or a roller bearing turbo but still t4 whats stronger
Old Nov 24, 2005 | 09:27 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
both EXACTLY the same RS500 spec T4 but one has a rollerbearing core and one has plain bearings?
is that what you asking?
as if you comparing two different turbos both called T4 but not both RS500 spec then itd be impossible to answer
Old Nov 25, 2005 | 08:03 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Roller bearings are stronger than thrust bearings. BUT, if a thrust bearing goes, it can be replaced. If the roller-bearing goes, it scraps the whole core .
Old Nov 26, 2005 | 09:47 AM
abdr500's Avatar
abdr500
Itsmeagain and Mike Rainbird that perfect m8 that s what i wanted to here
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
