Top speed of a RS500?
Nov 24, 2005 | 06:48 PM
What'd you reckon? - Three up at the time?
somewhere about 450bhp?
Nov 24, 2005 | 06:50 PM
Not too much more than the standard 3 door. I would guess at about an indicated 165-170mph
Nov 24, 2005 | 06:51 PM
standard running gear and rev limit will do about 176mph I think
and by running gear I don't mean the engine just the diff/box ratio
steve
Nov 24, 2005 | 06:53 PM
Does the RS500 have a different limiter and top cog / diff ratio from a 2wd saph?
If not, then 157mph
Neil.
Nov 24, 2005 | 07:03 PM
Quote:
If not, then 157mph
Neil.
TYPO thats what I meant 156 not 176
steve
Nov 24, 2005 | 08:50 PM
Hmmmm, thanks lads most interesting, i assume that'll be about 160-170 ish indicated then?
Nov 24, 2005 | 09:10 PM
OOOOOOOHHHHHHHH a good 80-90ish wind assisted.
Nov 24, 2005 | 09:13 PM
Quote:
is the indicated speed on a cossie not correct then???
Nov 25, 2005 | 07:11 AM
Of course not
My cossie is well out on GPS!
I had an old mk3 astra SRI that used to show nearly 130mph, but it was only about 116 off the GPS.
The most accurate one I've tested is my MK2 ST-24 which is always 2-3mph out, even at well over a tonne
Neil.
hopper350
Sep 4, 2015 12:53 AM
