Problem with my Punto!
Old Nov 24, 2005 | 12:46 PM
Poom's Avatar
Poom
Default Problem with my Punto!
I thought somebody may be able to help!
When the car is cold it will stutter badly for the first 5 minutes! IT is a 1.2 16v and I just wondered what it could be?
You will have your foot on the accelerator but it will just lose power then it will cut in again!
Thanks
Old Nov 24, 2005 | 12:52 PM
Physio's Avatar
Physio
Fooked plugs?
Old Nov 24, 2005 | 05:48 PM
dave green's Avatar
dave green
could be anything mate. the list would be as long as your arm.
Dave
Old Nov 24, 2005 | 05:49 PM
gurnE's Avatar
gurnE
1.2 punto? Wouldn't you need power first to loose it?
Sorry.
Is this only when it's cold? and how hard are you on the throttle?
Is the choke working?
Old Nov 24, 2005 | 05:52 PM
rapidcossie's Avatar
rapidcossie
try changing plugs or just let it heat up for a few mins before driving
Old Nov 24, 2005 | 05:55 PM
justin.e's Avatar
justin.e
could be the ecu as there was a recall on them!!
Old Nov 24, 2005 | 05:58 PM
warleydaddy's Avatar
warleydaddy
Had the same problem wite 2 Tipo`s ive had...
Theres a little fuel ECU that goes on them.ours went after about 75k...
sounds EXACTLEY like the prob u have....
Pete...
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
