Newman cam
Originally Posted by Tony Turbo
Did you buy Newman's own RST cam, or spec your own?
How many of you are on solid lifters?
this cam can only be used with solids
Originally Posted by T28 RST
Does anyone on here have one and what do they think of it
i am running a newman cam have done for the past two years
, this is the second one i have had due to me wanting a wilder profile, its not an off the shelf cam, newman cams can only use solid lifters because the cam material is made out of chill cast steel, if you tryed to use hydraulic lifters the cam would'nt last five minutes.. solid lifters Initially can be a pain to setup, because of the quality of the blanks i would'nt even bother with kent
piper are not as bad but you can't go wrong with newman....
T28 - its on solids? How many miles have u done/do you do? And how often does it need adjsuting? I do a lot of miles, so i'm not sure whether solids would be a viable option if i need to adjsut them every 3000 miles due to cam wear.
Originally Posted by Christian and Beccy
Anyone know what Poudage the Newman Springs are??
hi guys i am running a newman cam spec by ava solid lifters had a power engineering one before which i thought was the nuts but wow what a differance i found pulls hard and tails off longer just done 273 on the rollers so i recond a good choice
Newman quote their springs at 200lb - std ones are around 220lb, which is confusing. Maybe to do with the profile. If the 200lb ones work, then they are worth having, as will reduce wear problems.
Mc5506
Oct 5, 2015 09:57 PM
